Note: When you export the .xlsx
file, you might see the following pop-up window:
Figure 355 Excel file Alert
This is not an error message. Rather, It is a notification that some parts of the workbook (most likely charts) were repaired for the proper opening in Excel. You might encounter
this, for example, if you try to open a more or less complex Excel file with an OpenOffice Calc (and vice versa). The notification might also appear if you open a file with a
different version of Excel than the version that was used to create the file.
