Project Product view
You click on any system name in the Projects / Products view to go to the Projects / project_name / Products list for that specific system.
Each system’s view shows details and configurations options for the specific system that you clicked, including adapters and capacity. The tabs of this view are summarized in this reference chart:
Tabs of the Projects / project_name / Product list
System
Adapters
Capacity
Report
The preceding chart is repeated in each of the following linked sections. Click one of the following links to learn what you can do in the specific tabs of the list view:
You also have the option to add a system to the list by clicking Add Product+ in the Projects / Products view. (See also, “Adding a Product”.)
Figure 198 Multiple DS8000 systems in the initial Projects / Products list
