August 25, 2020 By Berjis Patel 3 min read
OpenShift® on IBM Power® Systems takes advantage of hybrid cloud flexibility, enterprise AI, and the security and robustness of the Power platform for private and public clouds. OpenShift is the Red Hat® cloud development platform as a service (PaaS) that enables developers to develop and deploy applications on public, private or hybrid cloud infrastructure. OpenShift 4, its latest version, is an Operator-driven platform that delivers full-stack automation from top to bottom. From Kubernetes to the core services that support the OpenShift cluster to the application services deployed by users, everything is managed throughout its lifecycle with Operators.
In this blog post, I’ll highlight 4 ways that OpenShift on IBM Power Systems is helping clients as they modernize applications and move to hybrid cloud.
4 benefits of Red Hat OpenShift 4 on Power
Red Hat OpenShift on Power Systems can be a building block in your journey to hybrid cloud. It’s well known that IBM Power Systems hosts mission-critical workloads and delivers excellent workload performance and reliability across industries. Now you can take advantage of this performance with container workloads using Red Hat OpenShift Container Platform. You can rapidly deploy OpenShift clusters using IBM PowerVC on Power Systems enterprise servers to help modernize your existing workloads.
Here are some of its advantages:
1. Flexibility
OpenShift on Power Systems can be deployed on IBM PowerVM and Red Hat KVM hypervisor, enabling you to use either scale-up or scale-out servers as required. You can also install Red Hat OpenShift bare metal on Power Systems.
2. Performance
Due to the simultaneous multithreading (SMT) technology on Power Systems, it’s possible to run more threads per core, which reduces the number of cores in comparison to an x86 system, achieving a 3.2X container density per POWER9 core. Depending on the types of workloads used — for example, a large-scale database, an AI or machine learning application or training modules — there’s a significant performance boost when using IBM Power Systems.
3. Better storage ROI
With the invention of IBM PowerVC Container Storage Interface (CSI) driver, you can take advantage of using existing block storage subsystems as persistent volumes for the container world. IBM PowerVC CSI driver bridges the need for persistent storage in a container environment by using your existing storage infrastructure.
Also, with the new addition of IBM Block Storage CSI driver, clients that don’t have PowerVC can leverage this CSI driver to directly access their existing IBM storage. The IBM Block Storage CSI driver for IBM Storage systems, can dynamically provision persistent volumes for block or file storage to be used with stateful containers, running in Red Hat OpenShift Container Platform.
The savings is manifested in many ways: new storage purchases and technology and training costs can be reduced or completely avoided.
4. Modernization and the hybrid cloud journey
Modernizing applications has become more critical than ever. Earlier apps can be difficult and costly to maintain, require antiquated or hard-to-find developer skills, and create a maze of disparate platforms that grow in complexity over time. OpenShift is built to help you make the shift to app modernization with greater ease, efficiency and precision. This Kubernetes-based platform enables you to achieve shorter application development cycles to deliver better quality software.
In addition to the many benefits of OpenShift on Power Systems, your journey to hybrid cloud can be further enhanced by IBM Cloud Pak® solutions built on Red Hat OpenShift, such as the Cloud Pak for Multicloud Management, Cloud Pak for Data and Cloud Pak for Applications. Together they provide a complete solution for AI, machine learning and cloud-native application workloads and management.
Red Hat OpenShift running on Power Systems is currently available on premises and in IBM Cloud data centers across the globe, as well as in partner cloud solutions (like Google Cloud and Skytap), to create a great synergy for your hybrid cloud environment. Thus, you now can deploy and manage your applications and services at your data center or in a public cloud. OpenShift’s ability to bring IBM Power Systems into the heterogenous container and virtualization environment is focused on hybrid, open cloud architecture and brings harmony to divergent hardware platforms that must coexist to make the business run.
Next steps
If you’re looking for support implementing OpenShift and hybrid multicloud on IBM Power Systems, contact IBM Systems Lab Services. And to learn more:
Was this article helpful?
YesNo
More from Cloud
Bigger isn’t always better: How hybrid AI pattern enables smaller language models
5 min read - As large language models (LLMs) have entered the common vernacular, people have discovered how to use apps that access them. Modern AI tools can generate, create, summarize, translate, classify and even converse. Tools in the generative AI domain allow us to generate responses to prompts after learning from existing artifacts. One area that has not seen much innovation is at the far edge and on constrained devices. We see some versions of AI apps running locally on mobile devices with…
IBM Tech Now: April 8, 2024
< 1 min read - ​Welcome IBM Tech Now, our video web series featuring the latest and greatest news and announcements in the world of technology. Make sure you subscribe to our YouTube channel to be notified every time a new IBM Tech Now video is published. IBM Tech Now: Episode 96 On this episode, we're covering the following topics: IBM Cloud Logs A collaboration with IBM watsonx.ai and Anaconda IBM offerings in the G2 Spring Reports Stay plugged in You can check out the…
The advantages and disadvantages of private cloud
6 min read - The popularity of private cloud is growing, primarily driven by the need for greater data security. Across industries like education, retail and government, organizations are choosing private cloud settings to conduct business use cases involving workloads with sensitive information and to comply with data privacy and compliance needs. In a report from Technavio (link resides outside ibm.com), the private cloud services market size is estimated to grow at a CAGR of 26.71% between 2023 and 2028, and it is forecast to increase by…
IBM Newsletters
