Project errors and warning
Errors and warnings can arise as you are creating and working with your storage system project. From the Projects tile view, the total number of Errors and Warnings for the project is
displayed in the upper-right corner of the project, as shown in
Figure 27.
Figure 27 Project Error s and warnings totals
Click a warning or error to go to the Products tab that contains the warning or error. Selecting the Warning/Error from the Products tab will display an information message, like the one
shown in
Figure 28. Review the error message and make the suggested changes in the
project configuration. Typically, making this change resolves the error.
Figure 28 Error/Warning message pop-up
