IBM STaaS Project Guide
Two types of To-Do lists are available in the Project Guide:
▪Pre-defined To-Do list: This list is automatically added to the Project Guide at the Solution Group-level when you create a STaaS Solution Group.
▪User defined To-Do list: If you have additional items to track, you can add extra lists for your project as follows:
a. Click the Project Guide bar on the right-most side of the window.
b. Click Add To-Do List and enter a name for your list.
c. Click the Add To-Do icon to add items one-at-a-time or click the
Import To-Do’s icon to import a list of items.
Figure 122
shows a sample STaaS Project Guide. For general information on the Project Guide, see
“Project Guide” on page 25.
Figure 122 STaaS Project Guide
