WWR2 : Creating IBM Storage Fusion products : IBM Storage Fusion software : IBM Storage Fusion software Project Guide
Two types of To-Do lists are available in the Project Guide:
Pre-defined To-Do list: This list is automatically added to the Project Guide at the Solution Group-level when you create an IBM Storage Fusion software Solution Group.
User defined To-Do list: You can add extra lists for your project if you have additional items to track, as follows:
a. Click the Project Guide bar on the right-most side of the window.
b. Click Add To-Do List and enter a name for your list.
c. Click the Add To-Do icon to add items one-at-a-time or click the Import To-Do’s icon, as shown in Figure 182, to import a list of items.
Figure 182 shows a sample IBM Storage Fusion software Project Guide. For general information on the Project Guide, see “Project Guide” on page 25.
Figure 182 IBM Storage Fusion software Project Guide
