Using dig +trace to understand DNS resolution from start to finish
Developer at desk with monitors
The dig command is a powerful tool for troubleshooting queries and responses received from the Domain Name Service (DNS). It is installed by default on many operating systems, including Linux® and Mac OS X. It can be installed on Microsoft Windows as part of Cygwin.
One of the many things dig can do is to perform recursive DNS resolution and display all the steps it took in your terminal. This is extremely useful for understanding not only how the DNS works but also for determining whether there is an issue somewhere within the resolution chain that causes resolution failures for your zones or domains.
First, let’s briefly review how a recursive query receives a response in a typical recursive DNS resolution scenario:
  1. You as the DNS client (or stub resolver) query your recursive resolver for www.example.com.
  2. Your recursive resolver queries the root nameserver for NS records for “com.”
  3. The root nameserver refers your recursive resolver to the .com Top-Level Domain (TLD) authoritative nameserver.
  4. Your recursive resolver queries the .com TLD authoritative server for NS records of “example.com.”
  5. The .com TLD authoritative nameserver refers your recursive server to the authoritative servers for example.com.
  6. Your recursive resolver queries the authoritative nameservers for example.com for the A record for “www.example.com” and receives 1.2.3.4 as the answer.
  7. Your recursive resolver caches the answer for the duration of the time-to-live (TTL) specified on the record and returns it to you.
The above process basically looks like this:
Step 1
Screenshot  showing Step 1 of recursive DNS resolution scenario
Step 2
Screenshot  showing Step 2 of recursive DNS resolution scenario
Step 3
Screenshot showing Step 3 of recursive DNS resolution scenario
Step 4
Screenshot  showing Step 4 of recursive DNS resolution scenario
Step 5
Screenshot  showing Step 5 of recursive DNS resolution scenario
This process occurs every time you type a URL into your web browser or fire up your email client. This illustrates why DNS answer speed and accuracy are so important: if the answer is inaccurate, you might need to repeat this process several times; and if the speed with which you receive an answer is slow, then it will make everything you do online seem to take longer than it should.
Driving both DNS answer speed and accuracy is at the core of the IBM® NS1 Connect® value proposition.
Author
Isaac Onigman
Technical Team Lead
IBM® NS1 Connect®
