DS8000 system specifications
The Storage Modeller user community depends on Storage Modeller for two major services:
▪Catalog current hardware, software, and version options for all systems.
▪Display valid options for each system that you are modeling, including cross-compatibility.
This section lists the DS8000 systems that Storage Modeller works with. Then, it describes how to you can access the raw technical specifications for those systems. These are the
specifications that Storage Modeller catalogs and selectively displays in its user interface.
