WWR2 : IBM Cloud Object Storage : Capacity modeling for IBM COS
To get started with capacity modeling, you can open an existing Project or start a New Project. This example starts with a New Project. When you click Add Product, the Storage Portfolio Selector is displayed and you follow this process:
1. Click the IBM Cloud Object Storage tile.
2. Select Add Product and the New Product dialog box is displayed.
3. Name the new system, and click Submit.
For more details about adding a product, see “Hosts tab (configure the hosts in a project)” on page 48.
When you are updating or adding a system, you reach the Products tab. This tab is the first in a set of four tabs. The IBM Cloud Object Storage tab and subsection Quick Select are selected by default.
