IBM InfoSphere Streams Version 4.1.1
Opening the instance graph
An instance graph provides a graphical view of the SPL applications that are running on a Streams instance. You can view the instance graph in the Instance Graph view.
Procedure
- In the Streams Explorer view, right-click an instance, or right-click a job shortcut in the Streams Jobs folder
- Click Show Instance Graph.
