IBM InfoSphere Streams Version 4.1.1
Instance graph basic features
You can use some of the basic features of the instance graph to focus and examine potential areas of concern.
Filters
If you have many jobs that are running on an instance, use filters to focus on specific jobs. You can filter jobs by job name, job ID, job owner, or job health. To apply a filter to the instance graph, click the Filter icon on the toolbar, and select the filter to apply.
Search
Use the search option to find elements in the instance graph. To search for an element:- In the Instance Graph view, from the toolbar, click the Search icon or press Ctrl+O.
- In the search window, start typing in the input area to display all elements that match the search criteria and are in the defined search scope.
Tip: Use tags
to mark elements that you want to quickly find in large graph, and
then modify the search scope to use only tags.
