Loading saved public views
You can load the saved public views.
Note:
- Click the
to see the Most used views . The Most used views lists the top three most used public or private views.
Procedure
Click the
icon.
- Select Load a Saved View to search and see all the saved private and public views.
- On the Load saved views window, select the Created by me checkbox for the views that you've created.
- Click load in individual window to display the saved private and public views.
