@botname help
This command is used to show inline help for commands.
Syntax
Usage
- list
- Shows available commands or version details. If you do not specify any action, this action is
the default action.
- command
- Shows the list of available commands for all resources. If you do not specify any object, this
object is the default object. To see the usage and examples of specific resource, you can click the
resource item to filter or to specify the available resource with the resource name in the command directly.
- resource_name
- This value is OPTIONAL. It specifies the name of the target resource that you want to
show.Note: You can see the usage and examples of the specified command. In the Usage section, values in the square brackets are optional for this command.
- version
- Shows the version, build number and build date of the current version of product.
Example
@bnz help
- Shows all resources.
@bnz help list command
@bnz help list command system
- Shows usage and examples of the system commands.
@bnz help list command automation-domain
- Shows usage and examples of the automation domain commands.
@bnz help list version
