Replacing a disk drive or SSD in the 8408-44E or 8408-E8E system with the power turned on in Linux
To replace a disk drive or solid-state drive (SSD) in a system with the Linux operating system or Linux logical partition that controls the drive location powered on, complete the steps in this procedure.
Procedure
- Ensure that you have the electrostatic discharge (ESD) wrist strap attached. If not, attach it now.
- Choose from the following options:
- On the console, complete the following steps:
- From the IBM Power RAID Configuration Utility display, select Work with disk unit recovery, and then press Enter.
- From the Work with Disk Unit Recovery display, select Concurrent add
device. Press Enter. A Concurrent Device Add display similar to the following example is shown. Figure 1. Example Concurrent Device Add display
Concurrent Device Add Choose a single location for add operations 1=Select OPT Name Platform Location Description Status --- ------ -------------------------- ------------------------- ---------------- U5887.001.Z065075-P1-D1 Empty U5887.001.Z065075-P1-D6 Empty U5887.001.Z065075-P1-D7 Empty U5887.001.Z065075-P1-D8 Empty U5887.001.Z065075-P1-D9 Empty e=Exit q=Cancel t=Toggle - Type 1 (Select) next to the location from which you removed the disk drive or solid-state drive. The Verify Device Concurrent Add display is shown. The service indicator flashes for that drive slot.
- Unlock the drive bay handle (A) by pressing it and pulling it out toward you. If the handle is not all the way out, the drive does not slide into the system. See Figure 2.
- Hold the drive by the top and bottom edges as you position the drive, and insert it into the drive slot.
- Slide the drive halfway into the system.
- Return to the console, and then press Enter. In the Verify Device Concurrent Add display, verify that the selected slot is the slot in which you want to install the drive.
- When the identify LED flashes for the selected slot, slide the
drive all the way into the slot, and push the drive bay handle (A) in until
it locks, as shown in Figure 2Important: Ensure that the drive is fully seated and is all the way into the system.Figure 2. Replacing a disk drive in an 8408-44E or 8408-E8E system
- On the console, press Enter on the Complete Device Concurrent Add display to indicate that the drive is installed. The service indicator stops flashing and turns off for that drive slot.
- If you are replacing more than one drive, repeat the steps in this procedure until all drives are replaced.
- To replace a 1.8-inch SSD in locations Un-P4-D10 through Un-P4-D13 in an 8408-44E or 8408-E8E system, continue with the next step.
device. Press Enter. A Concurrent Device Add display similar to the following example is shown. Figure 3. Example Concurrent Device Add display
- With the SSD drive bay handle (A)
in the unlocked position, pull the lever outward to gain access to the guide rails in the SSD slot.
Support the bottom of the SSD as you align it with the guide rails in the SSD slot. See Figure 4.Note: Support the drive by holding the drive by its sides.
- When the identify LED flashes for the selected slot, slide the drive all the way into the slot until the drive stops.
- Lock the drive by rotating the bay handle (A) in
the direction that is shown in Figure 4.Important: When you install an SSD, ensure that the SSD is fully seated and is all the way into the system.Figure 4. Replacing an SSD in an 8408-44E or 8408-E8E system
- If you are installing more than one drive, repeat the steps in this procedure until all drives are installed.
