Learn about the specifications and operating system requirements
for feature 5909.
Overview
The PCI Express
x8 Ext Dual-x4 3 Gb SAS Adapter and Cable Card is an x8 PCI Express
(PCIe) SAS adapter combined with a cable card in a single cassette
assembly. This feature provides an optimized 3/3 split storage device
backplane solution within a single PCIe slot for the model 9117-MMA system unit.
With this feature, three of the six internal serial-attached SCSI
(SAS) disk slots (4, 5, and 6) in the system unit enclosure are controlled
by the SAS adapter contained in this feature.
The single cassette
assembly goes in slot P1-C3 in the model 9117-MMA system unit.
The feature is not supported in any other models.
There are
three connectors on the tailstock of this single cassette assembly.
The top connector ( C in Figure 1.) is the cable card link to the
three internal SAS disk slots in the system unit. The middle connector
is covered with a label and is not used. The bottom connector ( D in Figure 1.) is the SAS adapter.
An
external AI-cable ( B in Figure 2) connects the top connector with
the bottom connector, thereby connecting the three internal SAS disk
slots to the SAS adapter. Both the top and bottom connectors are mini-SAS
4x ports.
The SAS adapter contained in this feature is a 64-bit,
bootable SAS adapter providing RAID 0, 5, 6, and 10 capability, but
with no write cache.
Figure 1 shows
the PCI Express
x8 Ext Dual-x4 3 Gb SAS Adapter and Cable Card in a cassette with the cassette
cover removed to show an internal view of the feature.
Figure 1. PCI Express
a cassette
- A
- Cable card
- B
- SAS adapter
- C
- 4x SAS port provides connection to the internal SAS disk slots
- D
- 4x SAS port for the SAS adapter
Figure 2 shows a
back view of model 9117-MMA with
feature 5909 installed and cabled.
Figure 2. Back
view of system unit with feature 5909 installed and cabled
- A
- Cassette containing feature 5909
- B
- SAS 4x AI-cable.
Specifications
- Item
- Description
- Adapter FRU number
- 44V4813 (Designed to comply with RoHS requirement.)
- I/O bus architecture
- PCIe x8
- Slot requirement
- PCIe slot P1-C3 in a model 9117-MMA system unit
- Cables
- SAS 4x AI-cable:
- FC 3679
- FRU number 44V4041
- SAS device attachment requires specific cables
that are provided with the subsystem or device features being attached. Special
cabling is required for multi-initiator and high availability configurations. See Serial
attached SCSI cable planning.
- Maximum number
- One per system unit enclosure.
- This feature is only supported in the P1-C3 slot in the model 9117-MMA system unit.
- Attributes provided
- One external 4x SAS port on the PCIe SAS adapter provides attachment
to the internal SAS disk slots using an external AI-cable attached
to the combined cable card.
- SAS Serial SCSI Protocol (SSP), Serial ATA Tunneling Protocol
(STP) and Serial Management Protocol (SMP)
- RAID 0, 5, 6, 10
- Concurrent Firmware Update
- 440 - 500 Mhz PowerPC (PPC)
- Optimized for SAS disk configurations that use dual paths through
dual expanders for redundancy and reliability.
This
adapter is supported for the following operating systems:
- AIX® Version 6.1 with the 6100-01 Technology Level, or
later
- AIX 5L™ Version 5.3 with the 5300-08 Technology Level
- Red Hat Enterprise Linux version
4, with update 7, or later
5, with update 2, or later
- SUSE Linux Enterprise Server 10, with service pack
2, or later
This adapter requires the following drivers:
- AIX: devices.pciex.14103903 device driver package
- Linux:
- iprutils version 2.2.8 and ipr driver version 2.0.11.6 (or newer)
for RHEL4 kernels
- iprutils version 2.2.8 and ipr driver version 2.2.0.2 (or newer)
for RHEL5 kernels
for SLES10 kernels
If
