Learn about the specifications and operating system requirements
for the 5904, 5906, and 5908 adapter.
Overview
The PCI-X DDR 1.5 GB cache SAS
RAID Adapter is a SAS disk controller with a maximum of 1.5 GB compressed
write cache and a maximum 1.6 GB compressed read cache. Auxiliary
write cache and concurrent battery maintenance are provided. The controller
is implemented using two physical adapters that are securely connected
to form a double-wide adapter. The double-wide adapter requires two
adjacent Peripheral Component Interconnect-X (PCI-X) slots. The auxiliary
write cache side of the double-wide adapter contains a dual, concurrently
maintainable cache battery pack which maintains cache memory on both
adapters in the event of an abnormal termination.
When used
in a logical partition (LPAR) environment, this double-wide adapter
must have both slots of the adapter assigned to the same logical partition.
When implementing dynamic LPAR (DLPAR), both slots of the adapter
must be managed together.
Feature 5904, 5906, and 5908 are
all feature codes representing the same PCI-X DDR 1.5 GB cache SAS
RAID Adapter. Different feature codes indicate if a blind swap cassette
is used and its type:
- Feature 5904 indicates no blind swap cassette. The feature is
used in enclosures that do not use blind swap cassettes.
- Feature 5906 indicates a gen-2.5 blind swap cassette. The feature
is used in the 5797 and 5798 enclosures.
- Feature 5908 indicates a gen-3 blind swap cassette. This feature
is used in the 5790, 5796, and 9117-MMA enclosures.
572F is the CCIN number on the RAID adapter side of the double-wide
adapter pair. 575C is the CCIN number on the write-cache adapter.
The
adapter provides RAID 0, RAID 5, RAID 6, and RAID 10 for the AIX® and Linux operating systems.
Under the IBM® i operating
system, mirroring, and data spreading are provided by the operating
system, and RAID 5 and RAID 6 are provided by the adapter. 1
The
adapter provides three mini-SAS 4x connectors for the attachment of
SAS drives located in 5886 EXP 12S Expansion Drawers. The adapter
supports a maximum of five 5886 EXP 12S Expansion Drawers.1 With
proper cabling and configuration, multiple wide ports are used to
provide redundant paths to each dual port SAS drive. If a SAS failure
occurs, then the adapter manages SAS path redundancy and path switching.
This
adapter supports the multi-initiator and high availability configurations.
With the optional pairing of adapter sets, an even higher level of
protection is provided by using a dual controller I/O configuration1 to
protect against the failure of an entire adapter set. In such a high
availability I/O configuration, SAS X cables are used to attach 5586
EXP 12S Expansion Drawers, and the fourth (top) mini-SAS connector
on each card set is used to directly connect the card sets by using
a SAS AA cable. See Serial
attached SCSI cable planning for
more information.
1 See POWER5 restrictions.
The following figure shows the adapter.
Figure 1. PCI-X
DDR 1.5GB cache SAS RAID Adapter
Note: Port T3 does not support any device attachment. T3 is
only used in dual controller I/O configurations for adapter to adapter
communication.
Specifications
- Item
- Description
- Adapter FRU number
- 44V8622 (Adapter only) (Designed to comply with RoHS requirement.)
- 44V7627 (Adapter in a gen-2.5 blind swap cassette)
- 42R4008 (Adapter in a gen-3 blind swap cassette)
- Battery FRU number
- 42R3965 or 74Y5665 (Designed to comply with RoHS requirement.)
- I/O bus architecture
- PCI-X
- Slot requirement
- Two, long, adjacent PCI-X slots.
- Cables
- SAS device attachment requires specific cables
that are provided with the subsystem or device features being attached. Special
cabling is required for multi-initiator and high availability configurations. See Serial
attached SCSI cable planning.
- Voltage
- 3.3V
- Form factor
- Long
- Maximum number
- See PCI adapter placement for machine types 82xx and 91xx.
- Attributes
- SAS speed: 3 Gbps
- SAS, SAS Serial SCSI Protocol (SSP) and Serial Management Protocol
(SMP) supported
- Single controller supported with SAS y cables (3692, 3693, 3694)
- Dual controller supported with SAS x cables (3661, 3662, 3663)
and SAS AA cable (3681, 3682)
- Single controller supports mirrored write cache data with auxiliary
cache
- Dual controller supports mirrored-write cache data and mirrored-RAID
parity footprints between card sets
- Solid state drives (SSDs)
supported
- Removable media devices are not supported
This
adapter is supported for the following operating systems:
- AIX:
- AIX 5L™ Version 5.3 with the 5300-07 Technology Level and
Service Pack 8, or later
- AIX 5L Version 5.3 with the 5300-08 Technology Level and
Service Pack 6, or later
the 5300-09 Technology Level and Service Pack 2, or later
the 5300-10 Technology Level, or later
- AIX 6.1 and
- AIX Version 6.1 with the 6100-01 Technology Level and
Service Pack 4, or later
6100-02 Technology Level and Service Pack 3, or later
6100-03 Technology Level, or later
- Linux:
- Red Hat Enterprise Linux version 4, with update 7,
or later
- Red Hat Enterprise Linux version 5, with update 2,
or later
- SUSE Linux Enterprise Server
10, with service pack 2, or later
- IBM i
- IBM i V5R4m5
and Resave F, or later
- IBM i 6.1
- IBM i 6.1.1
and Resave A, or later, is required for Dual Storage IOA support.
This adapter requires the following drivers:
- AIX: devices.pci.1410bd02
device driver package
- Linux:
- iprutils version 2.4.1 and ipr driver version 2.0.11.6 (or newer)
for RHEL4 kernels
- iprutils version 2.4.1 and ipr driver version 2.2.0.2 (or newer)
for RHEL5 kernels
for SLES10 kernels
If
the IBM Prerequisite Web site
Concurrent maintenance procedure
Concurrent
maintenance of this double-wide adapter is not supported through the
Hardware Management Console (HMC). Concurrent maintenance must be
done from within the partition operating system. In IBM i, the Hardware
Service Manager (HSM) of the system or owning partition will automatically
power off or on both PCI slots when either slot is selected. In AIX or Linux, you must manually
power off and on each slot separately.
Important: - Both PCI slots must be powered off when installing or removing
this adapter with the system power on.
- If this adapter is the load source IOA, or any other storage IOA
with critical DASD attached for the system, this concurrent maintenance
procedure should be done by a qualified service provider.
POWER5 restrictions
When the feature
is used in system configuration based on a POWER5 processor, the following restrictions
apply:
- A maximum of three 5886 EXP 12S Expansion drawers can be attached
per controller. with one on each port and no cascading.
- IBM i support only. AIX and Linux are not supported.
- IBM i load
source capability is not provided.
- The optional dual controller I/O configuration is not supported.
See also the following topics for the POWER5 restrictions:
