You might need to remove the voltage regulator assembly with the power on. Use the procedure in this section to perform this task.
If your system is managed by the Hardware Management Console (HMC), you can use the HMC to complete the steps for removing a voltage regulator module. For instructions, see Remove a part using the Hardware Management Console.
To remove a voltage regulator assembly, do the following:
