Troubleshooting
Problem
This document describes how to turn off the attention LED on IBM i systems or on the HMC GUI for server and partitions.
Resolving The Problem
Note, the following link contains supplemental information: https://www.ibm.com/support/pages/node/6891149
The partition attention indicator for an IBM i5/OS partition is turned on when the partition detects an event that requires service as indicated by a new entry in the Service Action log. On stand-alone systems the partition also controls the attention indicator on the front panel of the server.
On HMC-managed servers, the server attention indicator is turned on if there are one or more logical partitions with an attention indicator on or if there is a new serviceable event for the server as indicated by the HMC's Manage Serviceable Events. The attention LED on the server's physical control panel should match the logical attention indicator shown on the HMC.
Stand-alone Systems or IBM i logical partition
To turn off the system attention LED for an i5/OS partition (HMC-managed server) or a stand-alone i5 system (non-HMC-managed), do the following:
Step 1: On the operating system command line, type STRSST to start the System Service Tools.
Step 2: Sign on the System Service Tools.
Step 3: Select Option 1, Start a service tool, and press the Enter key.
Step 4: Select Option 7, Hardware service manager, and press the Enter key.
Step 5: Select Option 6, Work with service action log, and press the Enter key.
Step 6: Type an early date (for example, 05/05/77) to catch entries that might have been set from before the time of day was set.
A screen similar to the following is shown:
Step 7: Service Action Log entries are intended to be examined to determine what action is required. To clear the attention light, all errors must be acknowledged. This implies that the messages have all been reviewed. Press F6=Acknowledge All Errors.
Note: For stand-alone servers, this clears the attention light on the physical control panel. For HMC-managed servers, this clears the attention light that is set for this partition.
There are also options to close and delete entries that have been resolved.
HMC Version 7 and later: Turning off the server attention light.
Step 1: Check for serviceable events in the HMC.
Expand Systems Management > Servers. Select the server then Serviceability > Manage Serviceable Events. Click OK to view the events.
Review any serviceable events, contacting your hardware service provider as needed.
Note: If the server attention indicator was activated due to one or more logical partition indicators, the service event list may be empty.
Step 2: Deactivate System Attention LED.
With the server still selected, choose Operations → LED Status → Deactivate Attention LED.
Step 3: Confirm the deactivate
Confirm the operation is for the correct server and click OK.
Step 4: Close the panel.
Select Close.
HMC Version 7 and later: Turning off the partition attention indicator.
Note: This is an alternative procedure to using "F6=Acknowledge all errors" in the Service Action log.
Step 1: Deactivate Partition Attention LED.
In the navigation area, expand Systems Management, Servers, then click the target Server.
In the contents panel, select the partition. then click Operations → LED Status → Deactivate Attention LED.
Step 2: Confirm the deactivate.
Confirm the operation is for the correct partition and click OK.
Step 3: Click Close to close the panel.
HMC Version 6 and earlier: Turning off the server and partition attention light.
Expand Service Applications > Service Focal Point > Manage Serviceable Events. Accept the defaults and click OK.
Review any open service events contacting your hardware service provider if needed.
Step 2: Access Service Utilities.
Expand Service Applications > Service Focal Point > Service Utilities.
Step 3: Select the server. On the Selected pull-down menu, click on System Attention LED...:
Step 4: Select Deactivate System Attention LED.
Step 5: Alternate method to deactivate the logical partition attention indicator
To deactivate the attention on individual partitions, click on the partition and then click Deactivate partition LED in the Partition Operations pull-down menu.
Note: This turns off the attention indicator next to a particular partition on the HMC GUI, which is the same as doing an "acknowledge all" using the Service Action Log.
Select Close.
[{"Product":{"code":"SSB6AA","label":"Power System Hardware Management Console Physical Appliance"},"Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Component":"HMC","Platform":[{"code":"PF012","label":"IBM i"}],"Version":"5.3.0;5.3.5;5.4.0;5.4.5;6.1.0","Edition":"","Line of Business":{"code":"LOB08","label":"Cognitive Systems"}}]
Historical Number
377538346
Was this topic helpful?
Document Information
Modified date:
16 February 2023
UID
nas8N1015550
