IBM Support
Using HMC as Fix Repository to Update Power System Firmware
How To
Summary
The Power HMC Graphic User Interface (GUI) provides tools to retrieve system firmware updates from remote locations. If your data center is locked down such that remote access to IBM Electronic Services sites or even internal servers you might use to stage firmware fixes then another option you can employ is to push the fix files to the HMC using secure copy (SCP) then update the firmware using the HMC's disk as the repository.
Objective
Update or upgrade power system firmware using the HMC as a repository
Environment
Power HMC V9 and V10 (Power8, Power9 and Power10 systems)
Steps
1. Download the firmware to your workstation from IBM FixCentral
a. Starting URL is
   https://www.ibm.com/support/fixcentral/
b. Use the "Select Product" tab and pick Product Group "Power" from the drop down menu
image-20240408125508-1
c. Then pick the Make and Model type form the Product drop down menu as well as the firmware release you want.
NOTE: the example shown here is for 9105-22A.  Make sure you choose the make and model for the system you want to apply firmware on.
image-20240408125845-2
d. Once you press continue you will be presented with some options of firmware you can download within the release selected.  You will select the version you want to use then use the Continue button.
image-20240408130444-3
NOTE: Make sure you also click on the "Description" link so you can see the readme file for the firmware you select.  It will contain very useful data if you are trying to determine if the update will be concurrent or disruptive.
e. You will then need to authenticate with your IBM ID at the next screen.
f. Once you enter your IBM ID you will be presented with various options to download the firmware.
image-20240408130802-4
g. The next screen requires that you enter the 7-digit serial number of the entitled system you are applying firmware to.
NOTE: IBM uses an Update Access Key (UAK) to determine if the system you are trying to apply firmware to is entitled for hardware support.
h. If selecting the files to download you will only need the rpm and xml files for the fix to copy over to the HMC. (Note: If using Power10 or later, you will only need the .tar and .xml files.)
2. Secure copy the firmware files over to the HMC
a. If you are using a workstation operating system such as Linux or Mac OS then scp is native so syntax would look something like the following:
(1) On linux where scp protocol is native when using scp
scp /my_firmware_repository_dir/* user@hmc:/home/<user>
(2) On Mas OS where scp defaults to sftp protocol you need to add an additional option (-O) for the old scp protocol
scp -O /my_firmware_repository_dir/* user@hmc:/home/<user>
Example:
image-20240415164640-4
b. If you are using a Microsoft Windows workstation you will need an application that allows you to use SCP since its not a native Windows tool.  There are several tools one can find doing internet searches for applications that support the scp protocol for windows.   WinSCP is one such tool, but there are many others so find one that works for you and your enterprise and copy the firmware over to the HMC and put in /home/hscroot (or in your user's home directory if you have a unique admin user account.)
3. Update or upgrade the firmware of your Power server using the GUI when you have the "Mount Point" option for selecting a repository.
a. In later versions of the HMC the "Mount Point" option was added to the GUI so you could designate a directory location on the HMC's disk.  If the version you are using does not have the mount point option then skip to the next step where you can use the command updlic which does include mountpoint as an option.
b. Start the firmware update task by selecting the target system from the Systems menu and use the Firmware drop down menu option.
NOTE: The example used here is from HMC V10R2.1040.  Lower versions might show different screen presentations.
c. Select the "Update system firmware" task and step through the initial task steps to accept license agreement, perform readiness check and select the firmware operation type (update or upgrade). Then in the Repository selection choose "Mount Point" in the pull down menu.
d. Enter the directory path in the space provided for "Mount Point Directory" where you stored the firmware .rpm and .xml files (or .tar and .xml files for Power10 and Power11) , then press the Next.
e. The firmware fixes available in the directory for the update type you selected will be displayed.
NOTE: if you only scp over one firmware package then just that one will be displayed.
f. In the Summary task you will have a chance to review and then proceed with an install of the firmware once you hit the Install button.
g. When using the GUI there will be periodic status updates as the update progresses.
4. Update of upgrade the firmware of your Power server using updlic command
a. The option to update or upgrade firmware from a local filesystem on the HMC is available in the updlic command. On some earlier versions of HMC you had to use updlic if wanting to use the mount point option as the feature was not available in the GUI.
b. Syntax for and update or upgrade is similar, just a different flag used which can be seen if one were to review the man page for updlic (man updlic).  Following is an example of the syntax for doing an update within release.
updlic -m <system name> -o a -t sys -l latest -r mountpoint -d /home/hscroot
You can find the system name to use in above command by running
lssyscfg -r sys -F name
c. If you are performing and upgrade to a new firmware release then the option to use is "u" instead of "a".
Example:
updlic -m <system name> -o u -t sys -l latest -r mountpoint -d /home/hscroot
d. Upgrades from one release to another are disruptive and require the system to IPL while updates to a fix within the current release might not be.  Its important that you review the readme file for the firmware you are applying as it will allow you to determine if a fix update is concurrent or disruptive.
e. The update or upgrade should complete and you should see a message about the status.
5. Once the update or upgrade is complete you can check the level using the HMC GUI or using the command line (lslic) method
Example:
lslic -t sys -m <system name>
image-20240415134155-1
Document Location
Worldwide
[{"Type":"MASTER","Line of Business":{"code":"LOB08","label":"Cognitive Systems"},"Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"SSOQ2E","label":"Hardware Management Console V10"},"ARM Category":[{"code":"a8m0z000000bowEAAQ","label":"Hardware Management Console"}],"ARM Case Number":"","Platform":[{"code":"PF025","label":"Platform Independent"}],"Version":"All Versions"}]
Document Information
Modified date:
26 September 2025
UID
ibm17147754
