Question & Answer
Question
The Tivoli EIF probe does not run.
The command-line reports.
Problem running Java™ using $NCHOME/platform/linux2x86/jre_1.8.0/jre/bin/java.
Check the binary is accessible and has correct permissions
What is causing this issue?
[{"Type":"MASTER","Line of Business":{"code":"LOB77","label":"Automation Platform"},"Business Unit":{"code":"BU048","label":"IBM Software"},"Product":{"code":"SSSHTQ","label":"Tivoli Netcool\/OMNIbus"},"ARM Category":[{"code":"a8m500000008a63AAA","label":"Probes-\u003E1 Individual Probes-\u003ETivoli EIF nco_p_tivoli_eif"}],"ARM Case Number":"","Platform":[{"code":"PF025","label":"Platform Independent"}],"Version":"All Versions"}]
Log InLog in to view more of this document
This document has the abstract of a technical article that is available to authorized users once you have logged on. Please use Log in button above to access the full document. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
Was this topic helpful?
Document Information
Modified date:
09 May 2025
UID
ibm16557456
