IBM Support
System service parts - IBM System x3630 M3
Product Documentation
Abstract
System service parts for IBM System x3630 M3
Content
Move the pointer over the part for a description. Click the part to locate the part number.
migr_5088098_exploded_view.gif Cover Cover ServeRAID PCI riser-card Heat sink Microprocessor Memory Virtual media key Cover Power-supply paddle card System board Power-supply bay filler Chassis Simple-Swap Hard drive Hot-Swap Hard drive Hot-Swap Hard drive Hard drive filler Hard drive filler Bracket Backplane Backplane Air baffle USB board USB hypervisor key Fan board ServeRAID M5000 series battery
Item Description Replacement part number CRU/FRU type
1a Cover
(for 2.5-inch Hot-Swap hard drive) 69Y4533
1b Cover
(for 3.5-inch Hot-Swap hard drive) 69Y5273
2 ServeRAID
M1015 SAS/SATA adapter (models 32x and 42x) 46M0861
M5015 SAS/SATA adapter (battery not included) (models 62x and E2Y) 46M0851
M5014 SAS/SATA adapter (model 22x) 46M0918
3 PCI riser-card
(all models) 69Y1053
4 Heat sink
(all models) 69Y4249
5 Microprocessor
Quad-Core Intel Xeon L5609 1.86 GHz (12 MB cache) 40 W (all models) 69Y0783
Quad-Core Intel Xeon E5603 1.6 GHz (4 MB cache) 80 W (all models) 81Y5952
Quad-Core Intel Xeon E5506 2.13 GHz (4 MB cache) 80 W (models 22x and E1Y) 46D1270
Quad-Core Intel Xeon L5630 2.13 GHz (12 MB) 40 W (all models) 59Y3691
Quad-Core Intel Xeon E5606 2.13 GHz (8 MB cache) 80 W (all models) 81Y5953
Quad-Core Intel Xeon E5507 2.26 GHz (4 MB cache) 80 W (model 32x) 69Y0782
Quad-Core Intel Xeon E5607 2.26 GHz (8 MB cache) 80 W (all models) 81Y5954
Quad-Core Intel Xeon X5672 3.2 GHz (8 MB cache) 95 W (all models) 81Y5957
Six-Core Intel Xeon L5640 2.26 GHz (12 MB cache) 60 W (all models) 49Y7054
Quad-Core Intel Xeon E5620 2.4 GHz (12 MB cache) 80 W (model 42x) 49Y7053
Six-Core Intel Xeon E5645 2.4 GHz (12 MB cache) 80 W (all models) 69Y4714
Quad-Core Intel Xeon E5630 2.53 GHz (12 MB cache) 80 W (model 52x) 49Y7052
Six-Core Intel Xeon E5649 2.53 GHz (12 MB cache) 80 W (all models) 81Y5955
Quad-Core Intel Xeon E5640 2.66 GHz (12 MB cache) 80 W (all models) 49Y7051
Six-Core Intel Xeon X5650 2.66 GHz (12 MB cache) 95 W (model 62x) 49Y7040
Six-Core IntelXeon X5660 2.8 GHz (12 MB cache) 95 W (all models) 49Y7039
Six-Core Intel Xeon X5670 2.93 GHz (12 MB cache) 95 W (all models) 49Y7038
Six-Core Intel Xeon X5675 3.06 GHz (12 MB cache) 95 W (all models) 81Y5958
6 Memory
1 GB DDR3-1333 (Single-Rank) LP RDIMM (all models) 49Y1442
2 GB (Single-Rank) PC3L-10600R-999 LP RDIMM 1.35 V (all models) 49Y1410
2 GB (Single-Rank x8) PC3L-10600R-999 LP RDIMM 1.35 V (all models) 49Y1423
4 GB DDR3-1333 (Dual-Rank) RDIMM 1.35 V (all models) 49Y1412
4 GB (Single-Rank x4) PC3L-10600R-999 LP RDIMM 1.35 V (all models) 49Y1424
4 GB DDR3-1333 (Dual-Rank x4) LP RDIMM (models 32x, 42x, 52x, and 62x) 49Y1445
4 GB (Dual-Rank x8) PC3L-10600R-999 LP RDIMM 1.35 V (all models) 49Y1425
8 GB DDR3-1333 (Dual-Rank) LP RDIMM (all models) 49Y1446
8 GB (Dual-Rank) PC3L-10600R-999 RDIMM 1.35 V (all models) 49Y1415
8 GB (Dual-Rank) PC3L-8500R-777 RDIMM 1.35 V (all models) 49Y1416
16 GB (Quad-Rank x4) PC3L-8500R-777 RDIMM 1.35 V (all models) 49Y1418
7 Virtual media key
(all models)
49Y8425
8a Cover
Power Supply (all models) 69Y1046
8b Power-supply paddle card
(all models) 69Y5797
9 System board
(all models) 81Y6746
10 Power-supply bay filler
(all models) 49Y4821
11 Power supply
675 W 39Y7227
675 W 39Y7236
675 W, high-efficiency 39Y7218
12a Chassis
(for 3.5-inch Hot-Swap hard drive) 69Y4539
(for 2.5-inch Hot-Swap hard drive) 69Y4538
12b Simple-Swap Hard drive
3.5-inch 2 TB SATA (all models) 42D0788
3.5-inch 1 TB SATA (all models) 43W7625
13a Hot-Swap Hard drive
2 TB 3.5-inch SATA (all models) 42D0783
500 GB 3.5-inch SATA (all models) 39M4533
250 GB 3.5-inch SATA (all models) 40K6889
300 GB 15 000 rpm 3.5-inch SAS (all models) 44W2235
450 GB 15 000 rpm 3.5-inch SAS (all models) 44W2240
600 GB 15 000 rpm 3.5-inch SAS (all models) 44W2245
600 GB 10 000 rpm SFF SAS (all models) 49Y2004
13b Hot-Swap Hard drive
146 GB 10 000 rpm 2.5-inch (all models) 42D0633
300 GB 10 000 rpm 2.5-inch (all models) 42D0638
146 GB 15 000 rpm 2.5-inch (all models) 42D0678
500 GB 7 200 rpm 2.5-inch (all models) 42D0708
160 GB 7 200 rpm 2.5-inch (all models) 42D0748
500 GB 7 200 rpm 2.5-inch (all models) 42D0753
2 TB 6 GB 7 200 rpm 2.5-inch SAS (all models) 42D0768
1 TB 6 GB 7 200 rpm 3.5-inch SAS (all models)
42D0778
1 TB 2.5-inch SATA 43W7629
14a Hard drive filler
Hot-Swap ((models 22x, 32x, 42x, and 62x) 42R7992
14b Hard drive filler
Hot-Swap (models 52x and 72x) 44T2248
15a Bracket
3.5-inch Hot-Swap backplane bracket kit 69Y4524
15b Backplane
3.5-inch (4 x 3) without bracket 69Y4741
15c Backplane
2.5-inch Hot-Swap hard drive (with bracket) 69Y4526
16 Air baffle
(all models) 69Y1055
17 USB board
(all models) 69Y4244
18 USB hypervisor key
(all models) 49Y5375
21 Fan board
(all models) 69Y4246
Fan cage assembly
(all models) 69Y1056
  Backplane assembly
3.5-inch (2 x 1) (all models) 69Y4525
2.5-inch (2 x 2) (all modesl) 69Y4527
  Battery
3.0 volt 33F8354
  EIA LED board
(all models) 69Y4245
. Heat sink bracket
(all models) 46D1375
.. Fan
with cable (60 x 56 mm) (all models) 69Y1054
rear (all modes) 69Y4535
  Flash memory
2 GB (all models) 42D0545
. Front I/O
(all models) 69Y1050
. Front USB board
(all models) 69Y1052
.. Cover
Front I/O (all models) 69Y1049
Front USB (all models) 69Y4534
.. PCIe riser card
1 x 16 and 1 x 8 (all models) 69Y4242
1 x4 (all models) 69Y4243
. Cables
Backplane to PDB power (all models) 69Y4491
Fan power (all models) 69Y4211
Fan signal (all models) 69Y4489
I2C planar to Hot-Swap hard drive backplane (for 2.5-inch hard drive model) 69Y4495
I2C planar to to hot-swap hard drive backplane (for 3.5-inch hard drive model) 69Y4497
Interposer USB (all models) 69Y4212
iPass mini SAS 900 mm, 26-pin 69Y4493
iPass mini SAS 620 mm 69Y4496
iPass mini SAS 840 mm 69Y4494
LED signals 700 mm 69Y4492
ServeRAID battery (with interposer card) 44E8844
Y type power (all models) 69Y4490
  Cage
Rear 3.5-inch Hot-Swap (all models) 69Y4536
Rear 2.5-inch Hot-Swap (all models) 69Y4537
  Filler
Rear hard disk drive (all models) 69Y1047
  Latch
hard disk drive backplane (all models) 69Y4544
  Power cord
2.8 M (all models) 39M5377
. ServeRAID
ServeRAID M1000 series feature key (all models) 46M0864
ServeRAID M5000 series feature key (all models) 46M0931
. Rail kit
(all models) 69Y1044
. Label kit
3.5-inch (all models) 69Y4531
2.5-inch (all models) 69Y4530
. Miscellaneous kit
(all models) 69Y4532
. Keyboard
USB, US English (all models) 42C0060
USB UltraNAV, US English (all models) 40K9400
  Remote upgrade
(all models) 46C7532
. Mouse
USB wheel, 2-button (all models) 39Y9875
USB optical, 3-button (all models) 40K9203
. Alcohol wipe
(all models) 59P4739
Consumable parts are not covered by the IBM Statement of Limited Warranty. The following consumable parts are available for purchase from the retail store.
20 ServeRAID M5000 series battery
Battery (model 62x) 43W4342
Document Location
Worldwide
Operating System
System x:All operating systems listed
[{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXH0","label":"System x->System x3630 M3"},"Platform":[{"code":"PF025","label":"Platform Independent"}],"Line of Business":{"code":"","label":""}}]
Document Information
Modified date:
24 January 2019
UID
ibm1MIGR-5088098
