The following replaceable components are available for the System x3250 M2 Type 4190 or 4194 server.
Move the pointer over the part for a description. Click the part to locate the part number.
Item | Description | Part number | CRU |
1 | Cover |
(all models) | 42C1284 | |
2 | Riser card |
(all models) | 43W5112 | |
3 | SAS/SATA controller card |
Hot-swap (models 52x, 64x, 72x) | 43V7415 | |
4 | System board |
(all models) | 43W5103 | |
5 | SAS/SATA backplane 3.5-inch driver (hot-swap models) |
Hot-swap (models 52x, 64x, 72x, 82x, D4x) | 46C7919 | |
Hot-swap (models 52x, 64x, 72x) | 39M4349 | |
6 | SATA back plate, 3.5 inch drive |
(models 15x, 22x, 62x, B2x, C2x, D2x) | 39M4347 | |
7 | Power supply |
351 W (all models) | 39Y7289 | |
8 | Fan |
40 mm (all models) | 39M4322 | |
9 | Drive cage, 3.5 inch HS/SS hard disk drives |
(models 15x, 22x, 42x, 52x, 62x, 64x, 72x, 82x, B2x, C2x, D2x, D4x) | 42C1286 | |
10 | Bracket ear |
(all models) | 39M4351 | |
11 | Hard drive |
160 GB, simple-swap SATA (optional) | 39M4507 | |
250 GB, simple-swap SATA (optional) | 39M4511 | |
500 GB, simple-swap SATA (optional) | 39M4517 | |
750 GB, simple-swap SATA (optional) | 43W7575 | |
12 | Simple-swap filler panel (SATA) |
(models 15x, 22x, 62x) | 39M4343 | |
13 | Hot-swap filler panel (SAS/SATA) |
(models 52x, 64x, 72x) | 39M4375 | |
14 | Front bezel |
(all models) | 43W5115 | |
15 | Hard drive |
73 GB, 15000 rpm, hot-swap SAS (optional) | 39R7348 | |
146 GB, 15000 rpm, hot-swap SAS (optional) | 39R7350 | |
300 GB, 15000 rpm, hot-swap SAS (optional) | 43X0805 | |
160 GB, hot-swap SATA (optional) | 39M4525 | |
250 GB, hot-swap SATA (optional) | 39M4529 | |
500 GB, hot-swap SATA (optional) | 39M4533 | |
750 GB, hot-swap SATA (optional) | 43W7579 | |
16 | CD-RW/DVD-ROM drive |
24x, IDE (models 15x, 22x, 52x, 62x, 64x, 72x) | 44W4603 | |
24x, IDE (models 15x, 22x, 52x, 62x, 64x, 72x) | 43W4605 | |
DVD ROM drive, SATA (optional) | 44W3254 | |
DVD multi-burner drive, SATA (optional) | 44W3256 | |
17 | Operator information panel |
(all models) | 42C1513 | |
18 | CD/DVD-ROM interface board |
IDE (models 15x, 22x, 52x, 62x, 64x, 72x) | 39M4354 | |
SATA (models 42x, 82x, C2x, D2x, D4x) | 46C7838 | |
19 | Air baffle |
(all models) | 39M6296 | |
20 | Microprocessor |
2.2 GHz / 800MHz 1M dual core, E2200 (model B2x) | 46C1259 | |
2.0 GHz 512K single core (model 15x) | 43W5096 | |
2.4 GHz 2M dual core, E4600 (model 22x) | 44R5775 | |
2.53 GHz 1066 MHz 3M dual core, E7200 (model C2x) | 46M0338 | |
2.83 GHz 1333 MHz 12M quad core, x3360 (model 82x) | 44X0207 | |
3.0 GHz 6M dual core, E3110 Xeon (model 52x) | 44X0204 | |
3.16 GHz 1333 MHz 6M dual core, E3120 (model 42x) | 46M0339 | |
2.5 GHz 6M quad core, E3320 Xeon (model 62x, 64x) | 44X0205 | |
2.66 GHz 12M quad core, 3350 Xeon (model 72x) | 44X0206 | |
2.66 GHz 1333 MHz 6M quad core, x3330 (models D2x, D4x) | 46M0340 | |
21 | Heat-sink retention module |
(all models) | 43W5117 | |
22 | Heat-sink |
(all models) | 43W5116 | |
23 | Memory |
512 MB PC2-5300 ECC (all models) | 41Y2725 | |
1 GB PC2-5300 ECC (all models) | 41Y2728 | |
2 GB PC2-5300 ECC (all models) | 41Y2854 | |
512 MB PC2-6400 ECC (models 42x, B2x, C2x, D2x, D4x) | 46C7442 | |
1 GB PC2-6400 ECC (models 82x) | 46C7426 | |
2 GB PC2-6400 ECC (optional) | 46C7427 | |
. | Qlogic 4 Gbs PCI-E dual port fiber channel adapter |
(optional) | 39R6528 | |
. | Emulex 4 Gbs PCI-E dual port fiber channel adapter |
(optional) | 43W7512 | |
. | Qlogic 4 Gbs PCI-E single port fiber channel adapter |
(optional) | 39R6526 | |
. | Emulex 4 Gbs PCI-E single port fiber channel adapter |
(optional) | 43W7510 | |
. | 73.4 GB hard drive tray assembly |
(optional) | 43X0839 | |
. | Alcohol wipe |
(all models) | 59P4739 | |
. | 3.0 V battery |
(all models) | 33F8354 | |
. | Cables |
3.5 inch simple-swap SATA RAID (optional) | 43V7423 | |
Hot-swap SAS backplane (models 52x, 64x, 72x) | 42C1510 | |
Hot-swap power backplane (models 52x, 64x, 72x) | 42C1509 | |
Mini SAS-mini SAS, 1M, x4, male plug, universal keying (2,4,6) 28AWG (optional) | 39R6530 | |
Mini SAS-mini SAS, 4M, x4, male plug, universal keying (2,4,6) 28A WG (optional) | 39R6532 | |
SATA (simple-swap models) (models 15x, 22x, 62x) | 39M6276 | |
Operator information panel (all models) | 39M6266 | |
IDE, for CD/DVD interface card (all models) | 39M6267 | |
Cable, SATA, for SATA CD/DVD interface card (models 42x, 82x, B2x, C2x, D2x, D4x) | 25R5635 | |
PCI-X riser power (all models) | 41Y4165 | |
. | Chassis |
(all models) | 43W5119 | |
. | Miscellaneous parts kit 1 |
(all models) | 43W5120 | |
. | Miscellaneous parts kit 2 |
(all models) | 44X0213 | |
. | 1U Tool-less rail kit |
(all models) | 24P1121 | |
. | 2-post rail kit |
(all models) | 42C1069 | |
. | CRU/FRU label |
(all models) | 43W5114 | |
. | Hard drive installation label |
(all models) | 42C1282 | |
. | System service label |
(all models) | 43W5113 | |
. | NetXtreme 1000 Express G Ethernet adapter |
(optional) | 39Y6100 | |
. | NetXtreme II 1000 Express Ethernet adapter |
(optional) | 39Y6070 | |
. | NetXtreme II 1000 Express Ethernet adapter, dual port |
(optional) | 42C1782 | |
. | PCI-X riser card |
(optional) | 44T2007 | |
. | Pro/1000 PF server adapter |
(optional) | 42C1752 | |
. | Pro/1000 PT dual port server adapter |
(optional) | 39Y6128 | |
. | Pro/1000 PT quad port server adapter |
(optional) | 39Y6138 | |
. | Qlogic iSCSI dual-port PCIe HBA adapter |
(optional) | 42C1772 | |
. | Qlogic iSCSI single-port PCIe HBA adapter |
(optional) | 39Y6148 | |
. | IBM SAS HBA Controller adapter |
(optional) | 25R8071 | |
. | Rack power cord |
(all models) | 39M5377 | |
. | ServeRAID-MR10i adapter |
(optional) | 43W4296 | |
. | ServeRAID-MR10i adapter battery |
(optional) | 43W4299 | |
. | SCSI RAID adapter |
(all models) | 39R8852 | |
. | Thermal grease |
(all models) | 41Y9292 | |
. | UltraSlim enhanced multi-burner (slim Rambo 6) drive |
(optional) | 43W4607 | |
(optional) | 43W4609 | |
. | USB optical wheel mouse |
(optional) | 39Y9875 | |
. | USB 3 button optical wheel mouse |
(optional) | 40K9203 | |
1 | Cover |
2 | Riser card |
Hot-swap (models 84x, 74x, D6x) | 43V7415 | |
4 | System board |
5 | SAS/SATA backplane, 2.5 inch drives |
2.5-inch drives, hot-swap (models 66x, 74x, 84x, D6x) | 44W2728 | |
6 | Power supply |
7 | Fan |
8 | Drive cage |
2.5-inch, hot-swap HS hard (models 66x, 74x, 84x, D6) | 43W5133 | |
9 | Bracket ear |
10 | Hard drive |
73 GB, 2.5-inch, 10 000 rpm, hot-swap SAS (optional) | 39R7366 | |
146 GB, 2.5-inch, 10 000 rpm, hot-swap SAS (optional) | 43X0825 | |
11 | Hot-swap SAS filler panel |
(models 66x, 74x, 84x, D6x) | 26K8680 | |
12 | Front bezel |
13 | CD-RW/DVD-ROM drive |
24x (models 66x, 74x) | 43W4603 | |
24x (models 66x, 74x) | 43W4605 | |
24x (models 84x, D6x) | 43W3255 | |
DVD Ultra-slim SATA Multi-burner drive | 44W3256 | |
14 | Operator information panel |
15 | CD/DVD interface board |
(all models) | 39M4354 | |
16 | Air baffle |
17 | Microprocessor |
Quad-Core 2.5 GHz (6 MB L2 cache) (models 66x) | 44X0205 | |
Quad-Core 2.66 GHz (12 MB L2 cache) (models 74x) | 44X0206 | |
Quad-Core 2.66 GHz (6 MB L2 cache) (models D6x) | 44X0206 | |
Quad-Core 2.66 GHz (6 MB L2 cache) (models D6x) | 46M0340 | |
Quad-Core 2.83 GHz (1333 / 12 MB L2 cache) (models 84x) | 44X0207 | |
Quad-Core 3.0 GHz 12M quad-core (optional) | 44C6452 | |
18 | Heat-sink assembly retention module |
19 | Heat-sink assembly |
20 | Memory |
512 MB PC2-5300 ECC (model 66x) | 41Y2725 | |
512 MBDDRz-800 (model D6x) | 46C7442 | |
1 GB PC2-5300 ECC (model 74x) | 41Y2728 | |
1 GB DDR2-800 (model 84x) | 46C7426 | |
2 GB PC2-5300 ECC (optional) | 41Y2854 | |
2 GB DDR2-800 (optional) | 46C7427 | |
. | Qlogic 4 Gbs PCI-E dual portfiber channel adapter |
. | Alcohol wipe |
. | 3.0 V battery |
. | Cables |
Backplane, hot-swap SAS, for 2.5-inch hard drives (modls 66x, 74x) | 41Y3884 | |
Backplane, hot-swap power, for 2.5-inch hard drives (models 66x, 74x) | 43W5135 | |
Cable, SATA 24 inch (model 84x, D6x) | 25R5632 | |
. | Chassis |
. | Emulex Single Port 4 GB Single Port PCI-Express Fiber Channel Host BUS adapter |
(option) | 43W7510 | |
(all models) | 43W7512 | |
. | Keyboard, USB with trackpoint (optional) |
(all models) | 40K9400 | |
. | Keyboard, USB full width, black (optional) |
(all models) | 42C0060 | |
. | CRU/FRU label |
. | Netxtreme II 1000 Express Dual Port Ethernet adapter |
. | PRO/1000 PF server adapter |
. | PRO/1000 PT dual port server adapter |
. | PRO/1000 PT quad port server adapter |
. | QLogic iSCSI dual-port PCIe HBA adapter |
. | QLogic iSCSI single-port PCIe HBA adapter |
. | QLogic 10 GB CNA adapter |
(optional) | 42C1802 | |
. | QLogic 10 GB SFP + SR Optical Transceiver |
(optional) | 42C1816 | |
. | Remote Supervisor Adapter II |
(optional) | 44T1412 | |
(optional) | 43W4297 | |
(optional) | 43W4301 | |
. | SATA/SAS RAID adapter |
(optional) | 43W4341 | |
. | SATA/SAS RAID adapter battery |
(optional) | 43W4342 | |
. | SATA/SAS RAID adapter battery carrier |
(optional) | 43W4343 | |
