Product Documentation
Abstract
This document contains a table entitled IBM eServer xSeries 350 - System parts listing
Content
Hold your cursor over a part for a quick description. Click on the part to find the part number.
Want to see the supported options for your server?
Index | System - IBM eServer xSeries 350 - Type 8682 models 1RY, 2RY, 4RY, 5RY, 6RY | Replacement part number (FRU) |
1 | Top cover assembly | |
all models | 36L9611 | |
2 | Memory card with backer plate assembly | |
all models | 00N6637 | |
3 | CPU terminator card, slot 2 | |
all models | 94H0598 | |
4 | 92mm x 38 fan assembly | |
all models | 37L0305 | |
5 | Processor | |
700MHz/1MB, models 1RY, 4RY | 19K0911 | |
700MHz/2MB, models 2RY, 5RY | 19K0913 | |
900MHz/2MB, model 6RY | 24P3576 | |
6 | 92mm fan housing assembly with card guides | |
all models | 00N8981 | |
7 | LED/switch card | |
all models | 37L6460 | |
8 | SCSI backplane with backer plate assembly | |
all models | 00N8953 | |
9 | Slim hard disk drive bezel filler assembly | |
all models | 00N7259 | |
10 | Power supply filler panel | |
all models | 37L0331 | |
11 | 1.44MB diskette drive | |
all models | 76H4091 | |
12 | Front bezel assembly, 18mm | |
models 1RY, 2RY | 00N8971 | |
13 | CD-ROM | |
48x, all models | 06P5167 | |
48x, alternate | 19K1531 | |
48x, alternate | 33P3203 | |
48x, primary | 33P3207 | |
48x, alternate | 33P3211 | |
. | 18.2GB 15K-rpm Ultra 160 SCSI hot-swap SL hard disk drive (HDD) | |
06P5769, (Customer replaceable unit (CRU)) | ||
. | 36.4GB 15K-rpm Ultra 160 SCSI hot-swap SL HDD | |
all models | 06P5770, (CRU) | |
14 | 270W power supply with mounting | |
all models | 37L0311 | |
15 | Frame assembly (chassis) | |
all models | 36L9590 | |
16 | Power backplane assembly | |
all models | 00N6651 | |
17 | System board and backer plate assembly | |
all models | 00N6623 | |
18 | Service processor card assembly | |
all models | 00N6644 | |
19 | 120mm dual fan mount with cable assembly | |
all models | 09N7936 | |
20 | 120mm fan assembly | |
all models | 09N7938 | |
. | CD-ROM snap-on rails | |
all models | 00N6412 | |
. | Floppy disk drive slide assembly, left/right | |
all models | 00N6413 | |
. | 3u left EIA flange assembly | |
all models | 00N7190 | |
. | 3u right EIA flange assembly | |
all models | 00N7192 | |
. | Miscellaneous rack hardware kit | |
all models: Clips (12) Cage nuts (12) M6 screws (12) M4x5 screws (10) Velcro strips (10) | 00N7193 | |
. | Slide with brackets assembly | |
all models | 00N7205 | |
. | Rigid cable management arm | |
all models | 00N7211 | |
. | Miscellaneous plastics kit | |
all models: Memory card support guides (2) Processor support goalposts (2) DASD backplane locking latch (1) Fan housing locking latch (1) | 00N8961 | |
. | CPU terminator card guide/case, slot 2 | |
all models | 10L6936 | |
. | System service label | |
all models | 36L9586 | |
. | Front bezel | |
models 4RY, 5RY, 6RY | 06P5945 | |
. | On/Off switch cover | |
all models | 09N8012 | |
. | PCI hot plug switch card/housing | |
all models | 00N6665 | |
. | 128MB memory | |
all models | 33L3114 | |
. | 256 MB memory | |
all models | 33L3116 | |
. | 512 MB memory | |
all models | 33L3118 | |
. | 1024 MB memory | |
all models | 33L3120 | |
. | AC distribution box assembly | |
all models | 00N8955 | |
. | Cable, signal I2C - I/O planar to SCSI backplane ( 2x7) | |
all models | 00N7185 | |
. | Cable, signal lvd-SCSI - repeater to SCSI backplane | |
all models | 00N7198 | |
. | Cable, SCSI to bulkhead | |
all models | 06P5912 | |
. | Cable, 2 drop 120mm fan | |
all models | 09N7945 | |
. | Cable, 50 circuit signal with connector | |
all models | 09N7947 | |
. | Cable, 34 circuit floppy disk drive w / connector | |
all models | 09N7949 | |
. | Cable, power - power backplane to SCSI backplane and devices (4 drop) | |
all models | 36L9601 | |
. | Cable, signal - planar to CD-ROM (IDE) | |
all models | 36L9603 | |
. | Cable, power 24 circuit (power backplane - planar) | |
all models | 36L9605 | |
. | Cable, power - signal - power backplane to I/O planar 2x17 | |
all models | 36L9609 | |
. | Cable, power - I/O planar to fans 2x15 (5 drop) | |
all models | 36L9613 | |
. | Cable, signal planar to SCSI backplane | |
all models | 37L0350 replaced by 37L0147 | |
. | Power cord (1.8m/6ft in length) | |
6952301 (Power cords by country) | ||
. | Keyboards | |
all models | (Keyboards by country) | |
all models | 37L6579 | |
. | Backer plate and I/O planar assembly | |
all models | 25P3322 | |
. | CMOS Battery | |
all models | 33F8354 |
Document Location
Worldwide
[{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW18V","label":"Older System x->xSeries 350"},"Platform":[{"code":"PF025","label":"Platform Independent"}],"Line of Business":{"code":"","label":""}}]
Was this topic helpful?
Document Information
Modified date:
23 January 2019
UID
ibm1MIGR-4V2JF3
