Question & Answer
Question
Will a building block of type: Common work when added to 'System: Load Building Blocks'?
Answer
The rule, System: Load Building Blocks is an Event only rule. If a building block is created from Type: Common, which includes both Events and Flows, and is then added to the System: Load Building Blocks rule, it will load, but will only reflect Event offenses and not Flow offenses. Flow offenses can be triggered when using Flow rules, which are then bound to the building block used in a Flow rule.
Note: To use a type Common Building Block in a rule you need to apply it to a type Common Rule.
Rules of the type Common are used when Flows and Events need to be tested together in the same test, in sequence, in the same test group.
Was this topic helpful?
Document Information
Modified date:
24 April 2024
UID
swg21963724
