IBM Support
QLogic NetXtreme II device LED does not blink when using ASU - IBM System x
Troubleshooting
Problem
The NetXtreme II devices will fail to flash Light Emitting Diodes (LEDs) during system Power On Self Test (POST) if the Advanced Settings Utility (ASU) sets the 'BlinkLED' setting to a non-zero value. ASU will respond that the command to set the BlinkLED setting was successful. However, upon system restart, the LEDs of the adapter will not flash.
Resolving The Problem
Source
RETAIN tip: H213663
Symptom
Affected configurations
The system can be any of the following IBM servers:
The system is configured with at least one of the following:
The system is configured with one or more of the following IBM option part numbers:
The T7.10 level of firmware for the Broadcom NetXtreme II adapters is affected.
The system has the symptom described above.
Note: This does not imply that the network operating system will work under all combinations of hardware and software.
Please see the compatibility page for more information: http://www.ibm.com/systems/info/x86servers/serverproven/compat/us/
Solution
This fix was delivered in the NetXtreme II T7.12 firmware release.
Workaround
The user can blink the adapter's LEDs by setting a non-zero value (up to 15) to the adapter's Blink LED parameter in the system UEFI.
In UEFI, go to System Settings -> Network -> Adapter interface, and enter a non-zero value in the Blink LEDs field.
Additional information
The BlinkLEDs setting of the NetXtreme II adapter using ASU fails because the setting was not supported.
A NetXtreme II EFI driver fix has been developed by QLogic, and successfully blinks the LEDs using ASU. The fix will be included in the next NetXtreme II firmware release.
The workaround using UEFI allows the user to blink the LEDs until the next NetXtreme II firmware package is released.
Document Location
Worldwide
Operating System
System x:Operating system independent / None
System x Hardware Options:Operating system independent / None
Applicable countries and regions
  • Worldwide
[{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXB1","label":"System x->System x3950 X6"},"Platform":[{"code":"PF025","label":"Platform Independent"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXM0","label":"System x->System x3850 X6"},"Platform":[{"code":"PF025","label":"Platform Independent"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"QUOERDG","label":"System x Hardware Options->Ethernet->10 Gb->00D9700"},"Platform":[{"code":"PF025","label":"Platform Independent"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"QUOESPZ","label":"System x Hardware Options->Ethernet->10 Gb->44T1360"},"Platform":[{"code":"PF025","label":"Platform Independent"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"QUOESQI","label":"System x Hardware Options->Ethernet->10 Gb->94Y5180"},"Platform":[{"code":"PF025","label":"Platform Independent"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"QUOEWIQ","label":"System x->System x3750 M4->8752"},"Platform":[{"code":"PF025","label":"Platform Independent"}],"Line of Business":{"code":"","label":""}}]
Document Information
More support for:
Document number:
865800
Modified date:
30 January 2019
UID
ibm1MIGR-5096758
Manage My Notification Subscriptions
