IBM Support
Preparing for DB2® product installation on Power7® and Power7+ Systems
Preventive Service Planning
Abstract
This technote describes the DB2 installation requirements on Power7 and Power7+ systems.
Content
Power7 support for DB2 products:
If you plan to install DB2 products on Power7 systems, you must ensure that the minimum DB2 fix pack levels are met.
DB2 V9.1
DB2 V9.5
DB2 V9.7
DB2 V9.8
DB2 V10.1
AIX 5.3 TL9+
FP9
FP6a
FP2
Not Supported
Not supported
AIX 6.1 TL4+
FP9
FP6a
FP2
FP2
V10.1 GA
AIX 7
FP10
FP6a
FP3
FP3
V10.1 GA
For more information about the DB2 support on the AIX 7.1 operating system, refer to the following AIX 7.1 technote: http://www.ibm.com/support/docview.wss?uid=swg21447478
Here are a list of supported JAVA SDK for Power 7 systems:
http://www.ibm.com/developerworks/java/jdk/power7/index.html
Power7+ support for DB2 products:
If you plan to install DB2 products on Power7+ systems, you must ensure that the minimum DB2 fix pack levels are met.
DB2 V9.5
DB2 V9.7
DB2 V9.8
DB2 V10.1
AIX 6.1 TL7 SP6+
FP6a
FP2
FP4
V10.1 GA
AIX 7.1 TL1 SP6+
FP6a
FP3
FP4
V10.1 GA
For further discussion on this topic, visit this developerWorks forum thread:
https://www.ibm.com/developerworks/community/forums/html/topic?id=fbd8bbea-2f81-4789-91a4-aad421b7b4a1
[{"Product":{"code":"SSEPGG","label":"Db2 for Linux, UNIX and Windows"},"Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Component":"Install\/Migrate\/Upgrade - Database","Platform":[{"code":"PF002","label":"AIX"}],"Version":"9.8;9.7;9.5;9.1;10.1","Edition":"","Line of Business":{"code":"LOB10","label":"Data and AI"}}]
Document Information
Modified date:
16 June 2018
UID
swg21420730
