IBM Support
Post-Scan Engine dialog box prompt when using IBM FileNet Capture
Troubleshooting
Problem
Attempts to run DocProcessing on a batch or a Settings Collection result in a dialog box prompt when using IBM FileNet Capture. Note that the Capture installation did not have the DocProcessing option selected.
Symptom
The dialog box prompt shows:
The currently selected "Post-Scan Engine" is unable to perform image processing. Please select a correct "Post-Scan Engine" using the KSM (32-bit) in the control panel and try again
[{"Product":{"code":"SSNVMX","label":"FileNet Capture"},"Business Unit":{"code":"BU053","label":"Cloud \u0026 Data Platform"},"Component":"Capture Document Processing","Platform":[{"code":"PF033","label":"Windows"}],"Version":"5.2.1","Edition":"","Line of Business":{"code":"LOB45","label":"Automation"}}]
Log InLog in to view more of this document
This document has the abstract of a technical article that is available to authorized users once you have logged on. Please use Log in button above to access the full document. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
Document Information
Modified date:
28 April 2025
UID
swg21575505
