IBM Support
Operating System may hang if using UEFI for shutdown method - IBM Flex System, BladeCenter and System x
Troubleshooting
Problem
Xen SUSE Linux Enterprise Server (SLES) will hang on shutdown or reboot command. This happens intermittently but with more frequency on systems with memory in all the channels. The issue occurs when the user issues a reboot or shutdown command. For example, SlesXenPrompt> shutdown -r now The user may see a kernel panic or page fault or a hang. This information may be viewed by examining the dmesg.txt file on the next successful login (as root).
Resolving The Problem
Source
RETAIN tip: H213563
Symptom
For example,
Affected configurations
The system is configured with at least one of the following:
  • SUSE Linux Enterprise Server 11 Base Install XEN, Service Pack 1 XEN, Service Pack 2 XEN, Service Pack 3 XEN
This tip is not system specific.
This tip is not option specific.
The following system BIOS or UEFI level(s) are affected:
  • Build ID: CE4101U or later
Note: This does not imply that the network operating system will work under all combinations of hardware and software.
Please see the compatibility page for more information: http://www.ibm.com/systems/info/x86servers/serverproven/compat/us/
Solution
This behavior will be corrected in a future release of firmware.
The target date for this release is scheduled for fourth quarter 2014.
The file is or will be available by selecting the appropriate Product Group, type of System, Product name, Product machine type, and Operating system on IBM Support's Fix Central web page, at the following URL:
Workaround
Xen SLES allows the root user to specify which shutdown or reboot mechanism to use.
Users can edit elilo.conf to include reboot=a in the boot command line. This will force the reboot to use Advanced Configuration and Power Interface (ACPI).
This can be done via Graphical User Interface (GUI) YAST (Yet another Setup Tool) or editing elilo.conf directly with an editor. Here is an example of a line in elilo.conf modified to use acpi as its reboot mechanism.
For example:
  append = "resume=/dev/disk/by-id/scsi-35000c5006810b98b-part2 splash=silent crashkernel=256M-:128M reboot=a showopts"
Here are other options for the reboot parameter:
reboot
= t[riple] | k[bd] | a[cpi] | p[ci] | n[o] [, [w]arm | [c]old]
Default: 0
Specify the host reboot method.
Warm instructs Xen to not set the cold reboot flag.
Cold instructs Xen to set the cold reboot flag.
No instructs Xen to not automatically reboot after panics or crashes.
Triple instructs Xen to reboot the host by causing a triple fault.
KBD (Keyboard Controller) instructs Xen to reboot the host via the keyboard controller.
ACPI (Advanced Configuration and Power Interface) instructs Xen to reboot the host using RESET_REG in the ACPI FADT (Fixed ACPI Description Table)
Peripheral Component Interconnect (PCI) instructs Xen to reboot the host using PCI reset register (port CF9).
Additional information
The workaround will force the operating system to not use UEFI for its shutdown or reboot mechanism thus avoiding the issue path.
Document Location
Worldwide
Operating System
BladeCenter:SUSE Linux Enterprise Server 11
System x:SUSE Linux Enterprise Server 11
BladeCenter:SUSE Linux Enterprise Server 11 x86-64
System x:SUSE Linux Enterprise Server 11 x86-64
PureFlex System and Flex System:SUSE Linux Enterprise Server 11 x86-64
Lenovo x86 servers:SUSE Linux Enterprise Server 11
Lenovo x86 servers:SUSE Linux Enterprise Server 11 x86-64
Applicable countries and regions
  • Worldwide
[{"Type":"HW","Business Unit":{"code":"BU056","label":"Miscellaneous"},"Product":{"code":"HW19V","label":"BladeCenter->BladeCenter HS20"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB18","label":"Miscellaneous LOB"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW20D","label":"BladeCenter JS20 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW20G","label":"BladeCenter->BladeCenter HS40"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW21G","label":"BladeCenter->BladeCenter LS20"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU056","label":"Miscellaneous"},"Product":{"code":"HW21Q","label":"BladeCenter HS22"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB18","label":"Miscellaneous LOB"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW21X","label":"BladeCenter JS21 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU056","label":"Miscellaneous"},"Product":{"code":"HW22E","label":"BladeCenter->BladeCenter HS21"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB18","label":"Miscellaneous LOB"}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW22F","label":"BladeCenter->BladeCenter LS21"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW22G","label":"BladeCenter->BladeCenter LS41"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW22H","label":"BladeCenter QS20 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU056","label":"Miscellaneous"},"Product":{"code":"HW22I","label":"BladeCenter->BladeCenter HS21 XM"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB18","label":"Miscellaneous LOB"}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW22J","label":"BladeCenter->BladeCenter HC10"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW22K","label":"BladeCenter->BladeCenter HS12"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW22L","label":"BladeCenter JS12 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW22M","label":"BladeCenter QS22 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW22R","label":"BladeCenter JS22 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW22S","label":"BladeCenter QS21 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW22V","label":"BladeCenter->BladeCenter LS22"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW22W","label":"BladeCenter->BladeCenter LS42"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW22X","label":"BladeCenter->BladeCenter PN41"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW22Y","label":"BladeCenter JS23 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW22Z","label":"BladeCenter JS43 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW232","label":"BladeCenter->BladeCenter HS22V"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW233","label":"BladeCenter->BladeCenter HX5"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW234","label":"BladeCenter PS700 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW235","label":"BladeCenter PS701 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW236","label":"BladeCenter PS702 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW237","label":"BladeCenter PS703 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW238","label":"BladeCenter PS704 Blade"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW239","label":"BladeCenter->BladeCenter HS23"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW23F","label":"BladeCenter->BladeCenter HS23E"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB18","label":"Miscellaneous LOB"}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW312","label":"System x->System x3800"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW313","label":"System x->System x3650 T"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW314","label":"System x->System x3850"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW315","label":"System x->System x3950"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW316","label":"System x->System x3950 E"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW317","label":"System x->System x3500"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW318","label":"System x->System x3550"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW319","label":"System x->System x3650"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW321","label":"System x->System x3400"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW322","label":"System x->System x3455"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW323","label":"System x->System x3655"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW324","label":"System x->System x3755"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW328","label":"System x->System x3105"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB26","label":"Storage"}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW329","label":"System x->System x3200"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW331","label":"System x->System x3250"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW332","label":"System x->System x3850 M2"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW333","label":"System x->System x3950 M2"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW334","label":"System x->System x3200 M2"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW335","label":"System x->System x3250 M2"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW336","label":"System x->System x3350"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW337","label":"System x->System x3100"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW338","label":"System x->System x3450"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW339","label":"System x->System x3610"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HW341","label":"System x->System x3250 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW941","label":"Flex System p260 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW942","label":"Flex System p460 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW943","label":"Flex System p24L Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW944","label":"PureFlex System 42U Rack"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW945","label":"PureFlex System and Flex System->p470 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW946","label":"Flex System p270 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU056","label":"Miscellaneous"},"Product":{"code":"HW949","label":"PureFlex System and Flex System->Fabric Manager"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB18","label":"Miscellaneous LOB"}},{"Type":"HW","Business Unit":{"code":"BU058","label":"IBM Infrastructure w\/TPS"},"Product":{"code":"HW94A","label":"PureFlex System and Flex System->Flex System Manager Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"LOB57","label":"Power"}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW94B","label":"PureFlex System and Flex System->x220 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW94C","label":"PureFlex System and Flex System->x222 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW94D","label":"Flex System x240 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW94E","label":"PureFlex System and Flex System->x440 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW94F","label":"Enterprise Chassis"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW94I","label":"PureFlex System and Flex System->Flex System V7000"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW94J","label":"PureFlex System and Flex System->x880 X6 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW94K","label":"PureFlex System and Flex System->x280 X6 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HW94L","label":"PureFlex System and Flex System->x480 X6 Compute Node"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX10","label":"System x->System x3400 M2"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX20","label":"System x->System x3500 M2"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX30","label":"System x->System x3550 M2"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX40","label":"System x->System x3650 M2"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX50","label":"System x->System x3200 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX60","label":"System x->System x3250 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX70","label":"System x->System x3400 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX80","label":"System x->System x3500 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX81","label":"System x->System x3500 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX82","label":"System x->System x3530 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX90","label":"System x->System x3550 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWX91","label":"System x->System x3550 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXA0","label":"System x->System x3650 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXA1","label":"System x->System x3650 NAS"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXA2","label":"System x->System x3650 M3 HF"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXA3","label":"System x->System x3650 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU054","label":"Systems w\/TPS"},"Product":{"code":"HWXA4","label":"System x->System x3650 M4 HD"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXA5","label":"System x->System x3650 M4 BD"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXB0","label":"System x->System x3690 X5"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXB1","label":"System x->System x3950 X6"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXB2","label":"System x->System x3100 M5"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXC0","label":"System x->System x3850 X5"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXD0","label":"System x->System x3950 X5"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXE0","label":"System x->System x3100 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXG0","label":"System x->System x3620 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXG4","label":"System x->System x3300 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXG6","label":"System x->System x3750 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXH0","label":"System x->System x3630 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXH1","label":"System x->System x3630 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXJ0","label":"System x->System x3755 M3"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXK0","label":"System x->System x3100 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXL0","label":"System x->System x3250 M5"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXM0","label":"System x->System x3850 X6"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}},{"Type":"HW","Business Unit":{"code":"BU016","label":"Multiple Vendor Support"},"Product":{"code":"HWXX0","label":"Lenovo x86 servers->Lenovo System x3500 M4"},"Platform":[{"code":"PF047","label":"SurePOS"}],"Line of Business":{"code":"","label":""}}]
Document Information
More support for:
Operating system(s):
SurePOS
Document number:
865644
Modified date:
18 April 2023
UID
ibm1MIGR-5096652
