Troubleshooting
Problem
"Main method not found in class" error on running the java snippet that is created using the Generate Code from SQL option using the IBM Data Virtualization Studio
Symptom
On the IBM Data Virtualization Studio, when running the java snippet that is created using the Generate Code from SQL option on a Virtual Table, the below error is displayed
Main method not found in class xxx,
please define the main method as: public static void main(String[] args) or a
JavaFX application class must extend javafx.application.Application
Document Location
Worldwide
[{"Business Unit":{"code":"BU048","label":"IBM Software"},"Product":{"code":"SS4NKG","label":"IBM Data Virtualization Manager for z\/OS"},"ARM Category":[{"code":"","label":""}],"Platform":[{"code":"PF035","label":"z\/OS"}],"Version":"All Versions","Line of Business":{"code":"LOB76","label":"Data Platform"}},{"Business Unit":{"code":"BU048","label":"IBM Software"},"Product":{"code":"SSKRKK","label":"IBM Db2 Analytics Accelerator Loader for z\/OS"},"ARM Category":[{"code":"","label":""}],"Platform":[{"code":"PF035","label":"z\/OS"}],"Version":"All Versions","Line of Business":{"code":"LOB76","label":"Data Platform"}},{"Business Unit":{"code":"BU048","label":"IBM Software"},"Product":{"code":"SS3H8V","label":"IBM Open Data Analytics for z\/OS"},"ARM Category":[{"code":"a8m0z000000cxHeAAI","label":"IBM z\/OS Mainframe Data Service for Apache Spark"}],"Platform":[{"code":"PF035","label":"z\/OS"}],"Version":"1.2.0","Line of Business":{"code":"LOB70","label":"Z TPS"}},{"Business Unit":{"code":"BU048","label":"IBM Software"},"Product":{"code":"SS6QWT","label":"IBM QMF Analytics for Multiplatforms"},"ARM Category":[{"code":"a8m0z000000cxH0AAI","label":"QMF Data Service"}],"Platform":[{"code":"PF025","label":"Platform Independent"}],"Version":"All Version(s)","Line of Business":{"code":"LOB76","label":"Data Platform"}}]
Log InLog in to view more of this document
This document has the abstract of a technical article that is available to authorized users once you have logged on. Please use Log in button above to access the full document. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
Was this topic helpful?
Document Information
More support for:
IBM Data Virtualization Manager for z/OS
Software version:
All Versions
Operating system(s):
z/OS
Document number:
6538114
Modified date:
05 January 2022
UID
ibm16538114
Manage My Notification Subscriptions
