IBM Support
"Index and length must refer to a location within the string" when click 'Company/Data Entry – Reported values'
Troubleshooting
Problem
User clicks 'Company/Data Entry – Reported values'. An error appears.
Symptom
cid:image001.gif@01D0BF13.CB5DA460
Standard Error
Error Details:
Source: ControllerForms
Description: Index and length must refer to a location within the string.
Parameter name: length
at Cognos.Controller.ControllerForms.frmDataEntrySelection.AtFormLoad
(Boolean bExplicit)
frmDataEntryRepVal_Load(Object eventSender, EventArgs eventArgs)
[{"Product":{"code":"SS9S6B","label":"IBM Cognos Controller"},"Business Unit":{"code":"BU048","label":"IBM Software"},"Component":"Controller","Platform":[{"code":"PF033","label":"Windows"}],"Version":"10.2.0","Edition":"","Line of Business":{"code":"LOB76","label":"Data Platform"}},{"Product":{"code":"SSMRTZ","label":"IBM Cognos Controller on Cloud"},"Business Unit":{"code":"BU048","label":"IBM Software"},"Component":" ","Platform":[{"code":"","label":""}],"Version":"","Edition":"","Line of Business":{"code":"LOB76","label":"Data Platform"}}]
Log InLog in to view more of this document
This document has the abstract of a technical article that is available to authorized users once you have logged on. Please use Log in button above to access the full document. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
Document Information
Modified date:
08 May 2025
UID
swg21962300
