Troubleshooting
Problem
User receives error message when using Controller Excel link.
Symptom
English:
IBM Cognos 8 Controller Link
System.Web.Services.Protocols.SoapException: <.....>. --->
System.InvalidOperationException: Attempt to load Oracle client libraries threw BadImageFormatException. This problem will occur when running in 64 bit mode with the 32 bit Oracle client components installed. ---> System.BadImageFormatException: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
[OK]
German:
System.Web.Services.Protocols.SoapException: Die Anforderung konnte vom erver nicht verarbeitet werden. --->
System.InvalidOperationException: Der Versuch zum Laden von Oracle-Clientbibliotheken hat eine 'BadImageFormatException' ausgelost. Dieses Problem tritt bei Ausfuhrung im 64-Bit-Modus auf, wenn die 32-Bit-Clientkomponenten von Oracle installeiert sind. --->
Ausnahme von HRESULT 0x8007000B)
bei <....>
bei System.Data.OracleClient.OIC.DetermineClientVersion()
Cognos.Controller.Proxy.CCRWS.GetUserInfo ...
[OK]
[{"Product":{"code":"SS9S6B","label":"IBM Cognos Controller"},"Business Unit":{"code":"BU048","label":"IBM Software"},"Component":"Controller","Platform":[{"code":"PF033","label":"Windows"}],"Version":"8.5.1","Edition":"","Line of Business":{"code":"LOB76","label":"Data Platform"}},{"Product":{"code":"SSMRTZ","label":"IBM Cognos Controller on Cloud"},"Business Unit":{"code":"BU048","label":"IBM Software"},"Component":" ","Platform":[{"code":"","label":""}],"Version":"","Edition":"","Line of Business":{"code":"LOB76","label":"Data Platform"}}]
Log InLog in to view more of this document
This document has the abstract of a technical article that is available to authorized users once you have logged on. Please use Log in button above to access the full document. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
Was this topic helpful?
Document Information
More support for:
Software version:
8.5.1
Operating system(s):
Windows
Document number:
412747
Modified date:
08 May 2025
UID
swg21456317
Manage My Notification Subscriptions
