IBM Support
How to use SQL Profiler to create a SQL trace, for example to help troubleshoot Controller problems
Troubleshooting
Problem
Analyst/consultant would like to analyse what the Controller system is attempting to do, for example in order to troubleshoot an error message or performance problem.
How can they create a log of what the SQL server is doing, during a specific time period?
Symptom
Customer has an issue in Controller (for example slow performance when performing action X) and the support analyst would like to see if there is any useful information that can be found by analysing what actions the Microsoft SQL server is performing during this time.
  • In other words, they want to capture the SQL statements that are being run (by Controller) when the problem is occurring.
[{"Business Unit":{"code":"BU048","label":"IBM Software"},"Product":{"code":"SS9S6B","label":"IBM Cognos Controller"},"ARM Category":[{"code":"a8m0z000000bpPuAAI","label":"Other"}],"ARM Case Number":"TS004041733","Platform":[{"code":"PF033","label":"Windows"}],"Version":"All Version(s)","Line of Business":{"code":"LOB76","label":"Data Platform"}},{"Product":{"code":"SSMRTZ","label":"IBM Cognos Controller on Cloud"},"Business Unit":{"code":"BU048","label":"IBM Software"},"Component":" ","Platform":[{"code":"","label":""}],"Version":"","Edition":"","Line of Business":{"code":"LOB76","label":"Data Platform"}}]
Log InLog in to view more of this document
This document has the abstract of a technical article that is available to authorized users once you have logged on. Please use Log in button above to access the full document. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
Historical Number
1041324
Document Information
Modified date:
08 May 2025
UID
swg21372684
