Question & Answer
Question
How can I run a cluster analysis solution using centroid clustering and Ward's method, using Mahalanobis distance as the distance measure?
[{"Product":{"code":"SSLVMB","label":"IBM SPSS Statistics"},"Business Unit":{"code":"BU048","label":"IBM Software"},"Component":"Not Applicable","Platform":[{"code":"PF025","label":"Platform Independent"}],"Version":"Not Applicable","Edition":"","Line of Business":{"code":"LOB76","label":"Data Platform"}}]
Log InLog in to view more of this document
This document has the abstract of a technical article that is available to authorized users once you have logged on. Please use Log in button above to access the full document. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
Historical Number
25677
Was this topic helpful?
Document Information
Modified date:
16 April 2020
UID
swg21479518
