Question & Answer
Question
How to migrate a legacy FileNet workflow system to a CPE 5.2 workflow system?
Answer
In IBM Administrative Console for Content Engine (ACCE):
- Use the Object Store wizard to create an new Object Store that uses the same Database Connection and Schema as the Legacy Workflow System.
- Refresh the domain. The "Legacy Workflow System" will be moved under the new Object Store.
In some cases, this may also require the following:
Using IBM Administrative Console for Content Engine (ACCE):
On the isolated region, go to the properties tab, and on the Object Store property, select the newly created Object Store, and then "Save"
This will associate the region with the object store.
[{"Product":{"code":"SSNW2F","label":"FileNet P8 Platform"},"Business Unit":{"code":"BU053","label":"Cloud \u0026 Data Platform"},"Component":"Process Engine","Platform":[{"code":"PF033","label":"Windows"},{"code":"PF002","label":"AIX"},{"code":"PF016","label":"Linux"}],"Version":"5.2","Edition":"All Editions","Line of Business":{"code":"LOB45","label":"Automation"}}]
Was this topic helpful?
Document Information
Modified date:
07 December 2023
UID
swg21646092
