IBM Support
Differences between using a variable as a WEIGHT variable in SPSS and using it as a WLS or regression weight (REGWGT) in REGRESSION
Troubleshooting
Problem
I'm trying to clarify the effects of using the same variable with the WEIGHT command and using it as a regression or WLS weight via the REGWGT subcommand in the SPSS REGRESSION procedure. How will the two approaches affect my regression coefficients, standard errors and other basic regression results?
[{"Product":{"code":"SSLVMB","label":"IBM SPSS Statistics"},"Business Unit":{"code":"BU048","label":"IBM Software"},"Component":"Not Applicable","Platform":[{"code":"PF025","label":"Platform Independent"}],"Version":"Not Applicable","Edition":"","Line of Business":{"code":"LOB76","label":"Data Platform"}}]
Log InLog in to view more of this document
This document has the abstract of a technical article that is available to authorized users once you have logged on. Please use Log in button above to access the full document. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
Historical Number
57510
Document Information
Modified date:
16 April 2020
UID
swg21477175
