IBM Support
Creating the ActiveX Scripting engine failed. The Scripting engine is probably not correctly registered or CLSID is incorrect. The result code is 0x80004005
Troubleshooting
Problem
When using IBM® Rational® ClearQuest® Web, the following error is being generated: "Creating the ActiveX Scripting engine failed. Scripting engine is probably not correctly registered or CLSID incorrect. Result code is 0x80004005".
[{"Product":{"code":"SSSH5A","label":"Rational ClearQuest"},"Business Unit":{"code":"BU048","label":"IBM Software"},"Component":"Web ASP Client","Platform":[{"code":"PF033","label":"Windows"}],"Version":"2002.05.00;2002.05.20;2003.06.00;2003.06.12","Edition":"","Line of Business":{"code":"LOB77","label":"Automation Platform"}}]
Log InLog in to view more of this document
This document has the abstract of a technical article that is available to authorized users once you have logged on. Please use Log in button above to access the full document. After log in, if you do not have the right authorization for this document, there will be instructions on what to do next.
Historical Number
20892
Document Information
Modified date:
16 June 2018
UID
swg21134567
