Troubleshooting
Problem
A performance issue has been found that causes delays in the dispatching of shared processors partition. This affects shared processor partitions that are marked as capped or uncapped partitions that are in a defined shared processor pool. The circumvention to the problem is to create a new AIX or Linux partition and boot the partition to the SMS prompt. There is no need to install an operating system image for this partition. The following are step-by-step instructions to create this partition, once these steps are completed this should provide immediate relief to the performance problem. This defect is fixed in the following releases. F770.61 - GA F780.40 - GA F783.20 - GA F810.33 - GA F820.21 - GA F830.10 - GA
Symptom
High CPU queuing with low CPU utilization
Cause
Defect in hypervisor firmware
Environment
POWER7 and POWER8
Diagnosing The Problem
Contact iGSC performance team for verification
Resolving The Problem
Select the option to create an AIX or Linux partition from the HMC.
Specify a name for the partition, we used “circumvention”
Specify a name for the partition profile, we used “circumvention”
Indicate the partition is using shared processors
Indicate that the partition should be assigned 0.05 processor units, 1 virtual processor and specify the partition is uncapped.
Specify the partition as a dedicated memory partition with 256 MB of assigned memory.
Do NOT assign any I/O to the partition
Do not add any virtual adapters
Do not select any optional settings. Indicate to boot the partition to the system management services prompt.
Activate the new partition using the profile option
Boot the partition
Leave the partition in the activated state to circumvent the shared processor dispatching issue. If you need to reboot this entire system, remember to reactivate this partition to circumvent the problem. After loading the firmware service pack with the fix for this issue, you can power off and delete the partition.
Was this topic helpful?
Document Information
Modified date:
17 June 2018
UID
nas8N1020863
