Troubleshooting
Problem
The behavior of Dual In-Line Memory Module (DIMM) Single Bit Errors (SBE) and Multi-bit Errors are the same before memory initiation. This situation is due to the fact that the chip set cannot determine the difference between these errors before memory initiation. A Single Bit Error can be corrected after the system displays the message 'System initializing memory'. If a user installs a DIMM with a Single Bit Error on the system and powers on the system, it displays a DIMM error and disables the DIMM.
Resolving The Problem
Source
RETAIN tip: H212712
Symptom
Affected configurations
The system can be any of the following IBM servers:
- System x3100 M5, type 5457, any model
- System x3250 M5, type 5458, any model
This tip is not software specific.
This tip is not option specific.
Solution
No fix is planned. This is an Intel Haswell limitation.
Workaround
There is no workaround. If the Single Bit Error is detected in 'System initializing memory', this means that the DIMM has a physical defect, and changing the DIMM is recommended.
Additional information
Intel Haswell cannot determine the difference between a DIMM Single Bit Error and a DIMM Multi-bit Error in the beginning.
However, after the 'System initializing memory' message, the UEFI RAS code can process the errors, and separate a Single Bit Error from a Multi-bit Error.
(where RAS = Reliability Availability and Serviceability)Document Location
Worldwide
Was this topic helpful?
Document Information
Modified date:
30 January 2019
UID
ibm1MIGR-5095580
