Simplify collaboration complexity with IBM B2B Integration
As your B2B community expands, gain control by automating processes, protecting data, improving compliance and adding visibility.
IDC report: Driving Strategic Value with IBM B2B Integration
IBM B2B Integration Offerings
Supply Chain Business Network
Cognitive capability: Business transaction
Simplify B2B connectivity and leverage cognitive document correlation technologies for deep visibility into B2B transaction lifecycles. Reduce time to value by up to 85% with the ability to search and see the entire lifecycle of a transaction in real-time and in context of the entire transaction lifecycle.
B2B Integrator
Use this security-rich solution to integrate complex B2B processes across your community of trading partners while you improve availability and disaster recovery.
File Gateway
One solution to help you consolidate disparate file transfer activity and facilities, making them easier to integrate with your internal systems.
Transformation Extender
This solution enables your organization to integrate industry-based customer, supplier and business partner transactions across the enterprise.
