Starting the 5104-22C, 9006-12P, 9006-22C, or 9006-22P system
To start the system, complete the steps in this procedure.
About this task
Attention: For safety, airflow purposes and thermal performance, the service access cover must be installed and fully seated before you power on the system.
You can use this procedure to power on the system; or you can use a console and the IPMI tool to power on the system.
Procedure
  1. Before you press the power button, ensure that the power supplies are connected to the system unit and that the power cables are connected to a power source.
  2. Press the power button (7) shown in Figure 2.
    You may have to press the switch for 0.5 to 3 seconds.
    Figure 1. Power switch for 9006-12P
    Figure 2. Power switch for 5104-22C, 9006-22C, or 9006-22P
    Power switch for 9006-22C
What to do next
If you press the power button and the system does not start, contact your next level of support or your service provider.
