Installing a rear disk drive in the 9006-22P system
Learn how to install a disk drive in the rear of the IBM® Power® System LC922 (9006-22P) system.
Before you begin
Rear drives are an optional feature. You can install SATA and SAS rear drives with the system powered on and running.
About this task
Procedure
  1. Attach the electrostatic discharge (ESD) wrist strap.
    The ESD wrist strap must be connected to an unpainted metal surface until the service procedure is completed, and if applicable, until the service access cover is replaced.
    Attention:
    • Attach an electrostatic discharge (ESD) wrist strap to the front ESD jack, to the rear ESD jack, or to an unpainted metal surface of your hardware to prevent the electrostatic discharge from damaging your hardware.
    • When you use an ESD wrist strap, follow all electrical safety procedures. An ESD wrist strap is used for static control. It does not increase or decrease your risk of receiving electric shock when using or working on electrical equipment.
    • If you do not have an ESD wrist strap, just prior to removing the product from ESD packaging and installing or replacing hardware, touch an unpainted metal surface of the system for a minimum of 5 seconds. If at any point in this service process you move away from the system, it is important to again discharge yourself by touching an unpainted metal surface for at least 5 seconds before you continue with the service process.
  2. Unlock the drive bay handle (B) by pushing in the handle release (A) as shown in Figure 1. The handle (B) snaps out towards you. If the handle does not snap out all the way, the drive does not slide out of the system.
    Figure 1. Removing a rear drive
  3. If you are installing more than one drive, remove the other drive tray.
  4. Install a drive into the tray.
    Ensure that the tray is open. Orient the drive such that the connectors are pointing to the rear of the tray. Ensure that the screw holes (A) in the drive align with the pins (B) in the tray as shown in Figure 2.
    Figure 2. Inserting the rear drive in the tray
  5. While checking the alignment pins, press the sides (A) of the tray together until button (B) snaps into place as shown in Figure 3.
    Figure 3. Closing the rear drive tray
  6. Ensure that the drive handle is open. Support the drive by the bottom as you position the drive, and insert it into the drive slot.
    Ensure that the drive is fully seated and is all the way into the system.
  7. Lock the drive bay handle (A) by pushing in the handle release until it locks at (B) as shown in Figure 4.
    Figure 4. Disk drive lock detail
  8. For a non-RAID drive, configure the installed drive for your environment. If the drive is part of a RAID configuration, skip this step, the drive is detected and configured when inserted.
    After you insert the new drive, you need to rescan for the device.
    Ubuntu Linux® operating system
    To run the rescan-scsi-bus command in the Ubuntu Linux operating system, log in to the system as the root user, and run the following command:
    rescan-scsi-bus
    The rescan-scsi-bus tool is available in the scsitools package; install the package by using the following command:
    sudo apt-get install scsitools
    Red Hat Enterprise Linux (RHEL) version 7.2
    To run the rescan command in the REHL version 7.2 operating system, log in to the system as the root user, and run the following command:
    rescan-scsi-bus.sh -a
    The rescan-scsi-bus tool is available in the sg3_utils package; install the package by using the following command:
    yum install sg3_utils
    You can also refer to: Adding a Storage Device or Path.
  9. Load or restore data from your backup media.
