Settings (Alerting/Thold)
The page configures the Cacti alerting and threshold settings.
These settings are notfor the RTM alarm system. The alerts configured on the Alerting/Thold page are triggered by thresholds. For example, if an RTM graph monitors a host, the host memory usage goes beyond a predefined threshold, an email notification is triggered. The RTM alarm system can go beyond thresholds and send notifications based on data.
- General
- Basic configuration, which controls whether to send threshold notification or log breaches and changes.
- Logging
- Configures alert/threshold log level.
- Threshold Daemon
- Configures a dedicate threshold daemon and sets daemon process number.
- Alert Presets
- Configures weekend exemptions, default trigger Count or Re-Alerting poller cycles.
- Baseline Presets
- Controls whether RTM sends out baseline notifications.
- Default Syslog Settings
- Configures whether threshold events will be sent to syslog or not.
- SNMP Notification Presets
- Configures whether threshold events will be sent to SNMP notification receivers.
- Emailing Options
- Specifies the email sender information for notifications.
- Default Notification Options
- Controls dead host notification. Dead hosts are down or unreachable.
- Alert / Warning Message Defaults
- Configures default alert / threshold warning message.
- Alert Presets
- Sets the default alert level and related attributes.
