POWER7 information
Replacing a PCIe RAID and SSD SAS adapter in the 8233-E8B and 8236-E8C server with the power off
You can replace a PCIe RAID and SSD SAS adapter with the system power off.
Attention: If you are installing a new or upgraded
adapter, see Installing a PCI RAID and SSD SAS adapter in the 8233-E8B and 8236-E8C server with the power off to
obtain slot locations and required prerequisites. If you are replacing
an adapter as part of a service procedure, continue to use the following
procedure.
Use this procedure if you intend to remove a failing PCI RAID and SSD SAS adapter and replace it with the same type of adapter. The PCIe RAID and SSD SAS adapter is a double-wide adapter. Although it plugs into a single PCIe slot, two adjacent PCIe slots are required for installation.
You must have already completed the procedure Removing a PCI RAID and SSD SAS adapter from the 8233-E8B and 8236-E8C server with the power off in order to have the slot powered off.
To replace a PCIe RAID and SSD SAS adapter with the system power off, do the following steps:
