Previous topic |
Next topic |
Contents |
Contact z/OS |
Library |
PDF
![]() Linkage editor concatenation sequence z/OS ISPF User's Guide Vol II SC19-3628-00 |
The concatenation sequence used by ISPF to find the member for
input to the Linkage Editor is:
where type is whatever you specify on the panel.
For example, it can be OBJ or some other type containing Linkage Editor
language (LEL) control statements. If
the type is not OBJ, an OBJECT DDNAME is automatically allocated to
ease the use of these Linkage Editor control statements:
For example:
In this example, ISPF searches data sets XYZ.MYLIB.LEL and XYZ.MASTER.LEL
to find member TOP, which should contain LEL control statements. Also,
ISPF allocates to DDNAME OBJECT (DISP=SHR) these concatenated sequence
of object libraries:
This concatenated sequence is searched by the Linkage Editor if
member TOP contains INCLUDE OBJECT(member-name) statements. The concatenation
sequence passed to the Linkage Editor by way of the LIB parameter
has a type qualifier of LOAD and includes the system libraries you
specify, as follows:
This concatenation sequence is used by the Linkage Editor to resolve automatic call references. ![]() ![]() ![]() |
