CKF0098 Unexpected record length n at record nnn of DMSU volume dataset
Explanation
A record length smaller than 9 was encountered, this is not supported for a DMS unload (each record is expected to start with the 8 byte subfile name). The remainder of the data set will be skipped.
Severity
08
