Command reference (mmdas command)
The mmdas command manages IBM Storage Scale Data Access Services (DAS) service instances, accounts, and exports.
Synopsis
mmdas service create ServiceName --acceptLicense
                                 --ipRange IPAddressRange --scaleFactor ScaleFactor
                                 [ --scaleDataBackend FileSystemMountPoint ]
                                 [ --dbStorageClass CSIFilesetName ]
                                 [ --help ]
or
mmdas service delete ServiceName [ --help ]
or
mmdas service list [ ServiceName ] [ --output OutputFormat ] [ --help ]
or
mmdas service update ServiceName { --enable | --disable } --scaleFactor ScaleFactor
                                 { --enableMD5 | --disableMD5 } { --enableAutoHA | --disableAutoHA } [ --help ]
or
mmdas account create AccountName [ --gid GroupID ] [ --newBucketsPath BucketsPath ]
                                 [ --uid UserID ] [ --help ]
or
mmdas account delete [ AccountName | UserID:GroupID ] [ --help ]
or
mmdas account list [ AccountName | UserID:GroupID ] [ --output OutputFormat ] [ --help ]
or
mmdas account update AccountName [ --newBucketsPath BucketsPath ]
                                 [ --resetKeys ][ --help ]
or
mmdas export create ExportName  [ --filesystemPath FileSystemPath ] [ --help ]
or
mmdas export delete ExportName [ --help ]
or
mmdas export list [ ExportName ] [ --output OutputFormat ] [ --help ]
Availability
Available on all IBM Storage Scale editions.
Description
Use the mmdas command to manage IBM Storage Scale Data Access Services (DAS) cluster. The mmdas command communicates with the IBM Storage Scale DAS REST interface for performing the management functions.
Prerequisite: Before you can use the mmdas command, you must complete the post deployment steps. For more information, see Example configuration of IBM Storage Scale DAS.
Parameters
service
Manages the IBM Storage Scale DAS instance with one of the following actions.
create
Creates an IBM Storage Scale DAS S3 service instance with the specified parameters.
ServiceName
Specifies the name of the service instance that you want to create. IBM Storage Scale DAS only supports s3 as service instance name.
--acceptLicense
Accepts the IBM Storage Scale license. If you do not use this option, the license is not accepted.
Optional. Specifies the name of the storage class to configure a database for the S3 service.
Note: The dbStorageClass parameter is optional. The IBM Storage Scale DAS operator selects the storage classes defined on the OCP cluster by using spectrumscale.csi.ibm.com, if there is only one such storage class. If there are more than one storage classes defined on the OCP cluster using spectrumscale.csi.ibm.com as the provisioner, the DAS operator cannot automatically select one of those to configure the S3 service with. In such a scenario, you need to specify which of those storage classes must be used to configure the S3 service.
Optional. Specifies the file system mount point that is to be enabled for the S3 service interface.
Note: IBM Storage Scale DAS only supports scaleDataBackend with the S3 service.
Specifies the range of IP addresses that is to be used for the MetalLB configuration.
IPAddressRange has the following requirements:
  • It must be in the format: x.x.x.x-x.x.x.x
  • It must be in a sequence. For example, 192.0.2.11-192.0.2.15
  • It must match the number of OCP nodes which are labeled for IBM Storage Scale usage; nodes that have the scale=true label.
Specifies the number of IBM Storage Scale DAS labeled nodes on which the service endpoints can scale to. The default value is 1.
Note: Select a scale factor according to your requirements at the time of creating the service because the scale factor must not be changed during active I/O.
delete
Deletes the specified IBM Storage Scale DAS service instance.
ServiceName
Specifies the service instance that you want to delete. IBM Storage Scale DAS only supports s3 as service instance name.
list
Displays the information for the specified IBM Storage Scale DAS service instance or all service instances.
ServiceName
Specifies the name of the service instance for which you want to display the information. IBM Storage Scale DAS only supports s3 as service instance name.
Optional. Specifies the format of the output. You can specify json to generate output in the JSON format. The default output format is text.
update
Enables or disables the IBM Storage Scale DAS service instance.
ServiceName
Specifies the name of the service instance. IBM Storage Scale DAS only supports s3 as service instance name.
--disable
Disables the specified service instance.
--enable
Enables the specified service instance.
--disableMD5
Disables md5sum calculation for S3 objects at the S3 service level. The md5sum calculation is disabled by default.
--enableMD5
Enables md5sum calculation for S3 objects at the S3 service level.
--disableAutoHA
Disables automatic IP address failover and failback. Automatic IP address failover and failback is enabled at the time of the creation of the service instance.
--enableAutoHA
Enables automatic IP address failover and failback.
Note:
  • You must not change --scaleFactor during active I/O, otherwise I/O failure might occur. Change the scale factor during a maintenance window when there is no active I/O. For more information, see Changing scaleFactor might result in I/O failure.
  • You can set the --scaleFactor parameter only if the service is configured with --ipRange at the time of service creation.
account
Manages the IBM Storage Scale Data Access Services (DAS) S3 user accounts with one of the following actions:
create
Creates an IBM Storage Scale DAS S3 user account and generates the secret key and the access key for the S3 user account.
AccountName
Specifies the name of the S3 user account that you want to create.
--gid GroupID
Specifies the group ID that is associated with the S3 user account that you want to create.
Optional. Specifies the file system absolute path, which acts as a base path for S3 buckets created using S3 API by this user.
Note: When you specify this parameter for creating an account, the specified path is not validated. If the specified path is not valid, an error occurs when you try to create an export. Administrators must specify the newBucketsPath to enable s3 accounts of end users to create exports using the S3 IO path. If newBucketsPath is not specified for an S3 account, by default, the S3 user cannot create new exports and gets the AccessDenied error while trying to create an export using the S3 IO path.
--uid UserID
Specifies the user ID that is associated with the S3 user account that you want to create.
delete
Deletes the specified IBM Storage Scale DAS S3 user account.
Specifies the account name or the group ID and the user ID of the S3 user account that you want delete.
list
Displays the IBM Storage Scale DAS S3 user account information for the specified account name or the group ID and the user ID or all user accounts.
Specifies the account name or the user ID and the group ID of the S3 user account for which you want to display the information.
Note: The access key and the secret key associated with an S3 user account are only displayed in the output if you specify an account name with this command.
update
Updates the specified IBM Storage Scale DAS S3 user account.
AccountName
Specifies the name of the S3 user account that you want to update.
Specifies the file system absolute path for creating new buckets for the S3 user account that you want to update.
--resetKeys
Resets the S3 user account access key and secret key.
export
Manages the IBM Storage Scale Data Access Services (DAS) S3 exports with one of the following actions.
create
Creates an IBM Storage Scale DAS S3 export access with the specified parameters.
ExportName
Specifies the name of the S3 export that you want to create. The name of the export must:
  • consist of lower case alphanumeric characters, - (dash), or . (period)
  • begin and end with an alphanumeric character
  • have a length greater than or equal to 3 characters and less than or equal to 63 characters
Specifies the absolute path that is to be exported.
delete
Deletes the S3 export associated with the specified IBM Storage Scale DAS export name.
ExportName
Specifies the name of the S3 export that you want to delete.
list
Displays the information for the specified IBM Storage Scale DAS S3 export or lists all IBM Storage Scale DAS S3 exports.
ExportName
Specifies the name of the S3 export for which you want to display the information.
Exit status
0
Successful completion.
nonzero
A failure has occurred.
Security
You must have root authority to run the mmdas command.
Examples
  • mmdas service examples:
    1. To create an IBM Storage Scale DAS S3 service instance and accept the IBM Storage Scale license with the IP address range and the scale factor specified, issue the following command:
      mmdas service create s3 --acceptLicense --ipRange "192.0.2.12-192.0.2.14" --scaleFactor 1
      A sample output is as follows:
      Create request for Spectrum Scale Data Access Service: 's3' is accepted
    2. To create an IBM Storage Scale DAS S3 service instance and accept the IBM Storage Scale license while specifying the CSI fileset for the S3 service database and the file system for the data backend for the S3 service, issue the following command:
      mmdas service create s3 --acceptLicense --ipRange "192.0.2.12-192.0.2.14" --scaleFactor 1 --dbStorageClass ibm-spectrum-scale-csi-fileset --scaleDataBackend /mnt/fs1
    3. To list the information of IBM Storage Scale DAS service instances, issue the following command:
      mmdas service list
      Name   Enable  Phase
      s3     true    Ready
      • The Enable column shows whether the S3 service instance is enabled or disabled.
      • The deployment phase of the service instance shown in the Phase column can be one of the following values:
        • Ready: The service instance is ready to be used for S3 account creation or export creation.
        • Configuring: The service instance configuration is in progress.
        • Connecting: The service instance is trying to establish communication between the S3 endpoints and the S3 database.
        • Failed: The service instance configuration has failed.
        Attention: Once you issue the service creation command, for a brief period of time, the Phase column might be empty.
    4. To list the detailed information for the IBM Storage Scale DAS S3 service instance, issue the following command:
      mmdas service list s3
      Name   AcceptLicense   DbStorageClass                  Enable  EnableMD5
      s3     true            ibm-spectrum-scale-sample       true    true
      ScaleDataBackend       Phase   S3Endpoints
      [/mnt/remote-sample]   Ready   [https://s3-endpoints.example.com https://192.0.2.12 https://192.0.2.13 https://192.0.2.14]
      IpRange                EnableAutoHA    ScaleFactor
      192.0.2.12-192.0.2.14    true            1
    5. To update the scale factor for an IBM Storage Scale DAS service instance, issue the following command:
      mmdas service update s3 --scaleFactor 2
      Update request for Spectrum Scale Data Access Service: 's3' is accepted
    6. To enable md5sum calculation for S3 objects at the S3 service level, issue the following command:
      mmdas service update s3 --enableMD5
    7. To disable automatic IP address failover and failback, issue the following command:
      mmdas service update s3 --disableAutoHA
      A sample output is as follows.
    8. To delete an IBM Storage Scale DAS service instance, issue the following command:
      mmdas service delete s3
      IBM Spectrum Scale DAS service s3 delete request accepted
  • mmdas account examples:
    1. To create an IBM Storage Scale DAS S3 user account, issue the following command:
      mmdas account create s3user --gid 777 --uid 888 --newBucketsPath "mnt/fs1/fset1/user1_buckets"
      Account is created successfully. The secret and access keys are as follows.
      Secret Key					  Access Key
      q2F4l5tt8/8mFXt8YOroVrUPx80TW6dlrVYm/zGO	47al0MTOuj98WkgHWmti
    2. To list the account information for all IBM Storage Scale DAS user accounts, issue the following command:
      mmdas account list
      Name       UID	GID	New buckets path
      s3user1    888	777	/mnt/fs1/fset1/user1_buckets/s3user1_buckets
      s3user2    679	629	/mnt/fs1/fset1/user1_buckets/s3user2_buckets
      s3user3    478	128	/mnt/fs1/fset1/user1_buckets/s3user3_buckets
      s3user4    471	127	/mnt/fs1/fset1/user1_buckets/s3user4_buckets
      s3user5    431	124	/mnt/fs1/fset1/user1_buckets/s3user5_buckets
    3. To list the account information for a specified S3 user account in the JSON format, issue the following command:
      mmdas account list s3user1 -o json
      {"name":"s3user1","uid":888,"gid":777,"new_buckets_path":"/mnt/fs1/fset1/user1_buckets/s3user1_buckets",
      "access_key":"47al0MTOuj98WkgHWmti","secret_key":"q2F4l5tt8/8mFXt8YOroVrUPx80TW6dlrVYm/zGO"}
    4. To delete an IBM Storage Scale DAS S3 user account by specifying the account name, issue the following command:
      mmdas account delete s3user1
      Account is successfully deleted
      Note: Before deleting the S3 user account, you must delete the associated exports.
    5. To delete an IBM Storage Scale Data Access Services (DAS) S3 user account by specifying the group ID and user ID, issue the following command:
      mmdas account delete 888:777
    6. To update the bucket path and reset the access and secret keys for an IBM Storage Scale DAS S3 user account, issue the following command:
      mmdas account update s3user2 --newBucketsPath "mnt/fs1/fset1/sharedBuckets" --resetKeys
      Account is successfully updated
  • mmdas export examples:
    1. To create an IBM Storage Scale DAS S3 export, issue the following command:
      mmdas export create bucket2 --filesystemPath /mnt/fs1/fset1/bucket1
      Export is successfully created
    2. To list all IBM Storage Scale DAS S3 exports, issue the following command:
      mmdas export list
      Name
      bucket2
      bucket2user1
      user1bucket1
    3. To list the information of an IBM Storage Scale DAS S3 export, issue the following command:
      mmdas export list bucket2
      Name       Filesystem Path
      bucket2   /mnt/fs1/fset1/bucket1
    4. To delete an IBM Storage Scale DAS S3 export, issue the following command:
      mmdas export delete bucket3
      Export is successfully deleted
Location
/usr/local/bin
