Non-Goals
- Support for non-DOM implementations
- While the API SHOULD allow non-DOM implementations to be created, it is beyond the scope of the first version to ensure interoperability between implementations other than DOM. Additional standard service provider types MAY be added in the future and necessary API enhancements MAY be considered for a maintenance revision of JSR 106.
- Support for a higher-level API
- We expect that programmers MAY design high-level APIs which will be built on the JSR 106 API to hide low-level details, address common use-cases or apply profiling constraints. However, it is beyond the scope of the first version to support these requirements. A high-level API MAY be considered for a maintenance release of JSR 106.
- Support for user-pluggable algorithms
- Allowing developers to plug in their own implementations of XML Encryption algorithms without requiring them to create a complete JSR 106 implementation seems like a worthy goal but SHALL NOT be REQUIRED for this release of JSR 106. A solution we are investigating for a subsequent release of J2SE is to enhance the underlying JCA/JCE to add better support for registering, parsing and processing XML security algorithms, parameters, and key information.
