PCIe3 12 GB Cache RAID + SAS Adapter Quad-port 6 Gb x8 (FC EJ14; CCIN 57B1)
Learn about the specifications and operating system requirements for the feature code (FC) EJ14 adapters.
Overview
The PCIe3 4-port 12 GB Cache RAID + SAS Adapter is a PCI Express (PCIe) generation 3, x8, single-wide, full-height, short form-factor adapter that provides high-performance capabilities and supports the attachment of SAS hard disk drive (HDD) and SAS solid-state drive (SDD). A pair of FC EJ14 adapters are required to provide additional performance, mirrored write cache data and adapter redundancy. If the FC EJ14 pairing is broken, then the write cache is disabled. Integrated flash memory with super capacitors provides protection of the write cache without batteries in case of power failure. FC EJ14 effectively provides up to 12 GB of write cache that uses compression of 4 GB of physical cache.
The adapter provides four Mini-SAS HD (high density) narrow connectors for the attachment of SAS drives in the 5887 disk drive enclosure (IBM® EXP24S SFF Gen2-bay Drawer) as shown in Figure 1. Specific SAS cables with HD narrow connectors are used to attach to the 5887 disk drive enclosure. To provide the highest bandwidth, two AA SAS cables with HD narrow connectors are used to attach the two paired FC EJ14 adapters on the third and fourth adapter ports (T2, T3) to communicate status and cache content information. Both AA SAS cables are required unless 3 or 4 ports are being used to attach the SAS drives. When all connectors are attaching SAS drives, the communication between the adapter pair is performed through the SAS fabric by way of the disk enclosures and cabling. A maximum of 96 SAS devices are supported using four 5887 disk drive enclosure. The SAS devices can be all HDDs or can have up to 48 SSD + 48 HDDs (HDDs must be on the 3rd and 4th ports). They can have a maximum of 72 SSDs with no HDDs and must have an AA cable on the top port. If there are over 48 SSDs, then no HDDs can be attached.
The adapter provides RAID 0, RAID 5, RAID 6, RAID 10, RAID 5T2, RAID 6T2, RAID 10T2, and OS mirroring (LVM) for the AIX®, Linux, and VIOS operating systems. Under the IBM i operating system, the adapter provides RAID 5, RAID 6, OS mirroring, and data spreading. RAID 10 is supported by IBM i Version 7.2 or later.
For details about slot priorities and placement rules, see PCIe adapter placement rules and slot priorities and select the system you are working on.
Figure 1 shows the PCIe3 12 GB Cache RAID + SAS quad-port 6 Gb adapter. The connector plug (A) is installed in an empty port and prevents damage to that port whenever a cable for the adjacent port connectors is plugged-in or removed.
![PCIe3 12 GB Cache RAID + SAS 6 Gb Adapter](p7hcdfcEJ0L.gif)
Specifications
- Item
- Description
- Adapter FRU number
- 01DH742 (Designed to comply with RoHS requirement)
- Connector plug part number
- 00FW784 (The connector plug is installed in an empty port and prevents damage to that port whenever a cable for the adjacent port connectors is plugged-in or removed)
- I/O bus architecture
- PCIe 3.0 (compatible with 2.0 and 1.0)
- Slot requirement
- One PCIe x8 slot per adapter
- Adapters are installed in pairs
- For higher availability, place adapters in separate enclosures where supported
- Cables
- Specific X, YO, or AT SAS cable features with new narrow HD connectors are used to attach to the 5887 disk drive enclosure.
- SAS device attachment requires specific cables that are provided with the subsystem or device features being attached. Special cabling is required for multi-initiator and high availability configurations. See Serial attached SCSI cable planning.
- Supported Systems
- Power 8 processor-based server
- Voltage
- 3.3 V
- Form factor
- Short, full-height
- Maximum number
- For the maximum adapters supported, see the PCI adapter placement topic collection for your system
- Attributes provided
- Full high PCIe3 four port x8 adapter with up to 12 GB write cache
If you are installing a new feature, ensure that you have the software that is required to support the new feature and that you determine whether any prerequisites must be met for this feature and attaching devices. To check for the prerequisites, see IBM Prerequisite website.
- AIX
- AIX 6.1 with the 6100-09 Technology Level and Service Pack 5 and APAR IV68443, or later
- AIX 7.1 with the 7100-03 Technology Level and Service Pack 5 and APAR IV68444
- AIX 7.1 with the 7100-02 Technology Level and Service Pack 7, or later
- AIX 6.1 with the 6100-08 Technology Level and Service Pack 7, or later
- Linux
- Bare Metal Systems (Not supported)
- PowerKVM 3.1 Systems or PowerKVM 2.1 (Not Supported)
- Other environments
- Red Hat Enterprise Linux 7.2, big-endian, or later
- Red Hat Enterprise Linux 7.2, little-endian, or later
- Red Hat Enterprise Linux 6.8 or later
- SUSE Linux Enterprise Server 12, Service Pack 1, or later
- SUSE Linux Enterprise Server 11, Service Pack 4, or later
- Ubuntu Server 16.04, or later
- For support details, see the Linux Alert website.
- The latest version of the device driver or iprutils can be downloaded from the IBM Service and Productivity Tools website.
- IBM i
- IBM i Version 7.3, or later
- IBM i Version 7.2, Technology Refresh 4, or later
- VIOS
- VIOS 2.2.3.51, or later
