IBM ARTIC960Hx 4-Port Selectable PCI Adapter (FC 2947)
Learn about the specifications for the IBM® ARTIC960Hx 4-Port Selectable PCI Adapter.
Overview
The IBM ARTIC960Hx 4-Port Selectable PCI Adapter consists of an IBM ARTIC960Hx Base PCI Adapter, an IBM ARTIC960 4-Port Selectable PCI Mezzanine Card (PMC), and an 8MB DRAM Memory card.The Base PCI Adapter provides high-function control of I/O operations and serves to off-load input/output tasks from the system microprocessor. It has a memory connector that supports 8 MB of extended-data output (EDO) dynamic random-access memory (DRAM).
The 4-Port Selectable PMC connects to the Base PCI adapter by two 64-pin connectors. The PMC card provides a high-function, application-specific interface that expands the capability of the base adapter.The Base PCI Adapter and the attached 4-Port Selectable PMC occupy a single 32-bit expansion slot.
In addition to this topic, you can learn more about the adapter in the IBM ARTIC960Hx 4-Port Selectable PCI Adapter, IBM ARTIC960Hx 4-Port T1/E1 PCI Adapter, IBM ARTIC960Hx DSP Resource PCI Adapter Installation and User's Guide SA23-2577
Figure 1 shows a side view of the IBM ARTIC960Hx Base PCI Adapter.
![Side view of the Base adapter](a4aa2935.gif)
Figure 2 shows a side view of the 4-Port Selectable PMC.
![Side view of the PMC](a4aa2937.gif)
Adapter specifications
- Item
- Description
- FRU numbers
- Base adapter, 87H3427
- 8 MB memory module, 87H3621
- 4-Port selectable mezzanine card, 87H3413
- I/O bus architecture
- PCI, 32-bit, 33-MHz
- The 2947 can be installed in supported 32-bit or 64-bit, 33-MHz, 66-MHz, 133-MHz, and 266-MHz PCI and PCI-X bus slots.
- Busmaster
- Yes
- Bus size
- 32-bit
- Wrap plugs
- See Wrap plugs
- Cables
- EIA-232 (ISO 2110) cable
- EIA-530 (ISO 2110) cable
- V.35 DTE (ISO 2593) cable
- RS 449 (ISO 4902) cable
- X.21 (ISO 4903) cable
If you are installing a new feature, ensure that you have the software that is required to support the new feature and that you determine whether there are any prerequisites for this feature and attaching devices. To check for the prerequisites, see IBM Prerequisite website .
Wrap plugs
FRU number | Description of wrap plug |
87H3311 | 120-pin connector |
87H3439 | 25-pin wrap plug (EIA-232 (ISO 2110) or EIA-530 (ISO 2110)) |
87H3442 | 34-pin wrap plug (V.35 DTE (ISO 2593) 34-pin male block) |
87H3440 | 37-pin wrap plug (RS-449 (ISO 4902)) |
53G0638 | 15-pin wrap plug (X.21 (ISO 4903)) |
Port speeds
When clocks are supplied by an external device (all interfaces except EIA-232), the 4-Port Selectable PMC supports four ports running simultaneously at a maximum data rate of 2.048 Mbps, duplex, and synchronous. The following table shows the maximum speed supported for each electrical interface.
Electrical interface | Maximum speed per port |
EIA-232 (ISO 2110) | 38.4 Kbps (U.S. only) 19.2 Kbps (EMEA only) |
EIA-530 (ISO 2110) | 2.048 Mbps |
V.35 DTE (ISO 2593) | 2.048 Kbps (US only) 64 Kbps (EMEA only) |
RS 449 (ISO 4902) | 2.048 Mbps |
X.21 (ISO 4903) | 2.048 Mbps |
Clocks supplied by a Dual Universal Serial Communications Controller (DUSCC) on the 4-Port Selectable PMC provide synchronous data rates up to 230.4 Kbps, duplex. In addition, an on-card clock generator can provide data rates of either 1.544 Mbps or 2.048 Mbps for each port. Selection of the clock frequency is programmable.
4-Port Selectable PMC 120-pin connector
The individual signals for all ports connect to the 4-Port Selectable PMC through the 120-pin connector at the rear of the card. Each cable has a single 120-pin, male, D-shell connector that branches into four individual cables, each of which provides access to one of four independent ports. The 120-pin D-shell connector is shown in the following illustration.
![120-pin connector](a4aa2940.gif)
