Learn how to install a disk drive or solid-state drive in a system or expansion unit with the AIX® operating system or logical partition that controls the drive location is powered on.
To replace a drive, you must first ensure that the slot it will occupy does not contain another drive or a disk drive filler. For the procedure to remove a drive, see Removing a disk drive or solid-state drive from the 8412-EAD, 9117-MMB, 9117-MMC, 9117-MMD, 9179-MHB, 9179-MHC, or 9179-MHD with the AIX system or logical partition power turned on. For the procedure to remove a disk drive filler, see Removing a disk drive filler from the 8412-EAD, 9117-MMB, 9117-MMC, 9117-MMD, 9179-MHB, 9179-MHC, or 9179-MHD.
If you are replacing a drive as part of a service procedure, continue to use the following procedure.
Complete the following steps to replace a solid-state drive in the EDR1 PCIe storage enclosure.
Complete the following steps after you install or replace the disk drive or solid-state drive in a system, enclosure, or expansion unit:
